Audio Notes venner
  • Erland
    Audio notes venner
    Er det noen av dere DAC-tweakere som har forsokt aa kjore USB eller optisk signal fra server inn i stedet for fra CD-transport?
    Er det praktisk mulig aa faa til en kombinsjon med inngangsvelger man kan switche mellom CD-transport og Server?
    Erland (som ennaa ikke har begynt aa utforske DAC-mysteriet)
    OivindJ
    Audio notes venner
    Vet ikke om det er slik ennå, men:
    http://www.mostlyaudio.com/DAC21_BuildMain.html
    Testing USB Operation
    Now, I opted for the USB option simply because I was curious. Curious because I had been hearing highly conflicting reports about the quality that could be gained. Some people said it was useless; others said it was superb. So I had to find out for myself.
    To switch between normal and USB input, you have to flip a switch that is located on the back edge of the digital board. In the DAC Kit 1.1, this switch extends through the chassis to enable switching between RCA and XLR inputs. However, in this kit it looks like the digital board had to be moved away from the back of the chassis to allow room for the USB board.
    When you plug the USB cable into the DAC, the computer should automatically recognise it as a USB Audio DAC (or at least my Dell PC running XP does). The computer then defaults to outputting to it unless applications have other output devices configured specifically. This means that even normal computer sounds are directed to the DAC - I wasn't expecting that and see it as a bonus although I'm not exactly sure at this stage how it decides on how to convert things.
    I already had a number of CD's copied to a few directories. I copied these using Exact Audio Copy which is a freeware program - creating bit image WAV files. I first played back by simply double-clicking on the files and letting Windows Media Player play them. Later, I began to use Foobar 2000 because that let me configure the method to use to output (DirectSound v2, Kernel Streaming, etc).
    Unexpected Results
    I was totally surprised at the quality of output that the USB interface allowed.
    I didn't really think that I would want to use this option as a regular thing but I now knew that I had to experiment further. To enable me to do this, I decided that I would perform one last operation before securing the lid of the unit.
    So, I went out and bought a small toggle switch that I could fit in the remaining RCA hole in the back panel. I then connected 3 wires to it, connected the other ends of the wires to the legs of the switch on the digital board, and finally snipped each leg in two places so there was now a gap - leaving the old switch now totally disconnected.
    BHO
    Asker
    Audio notes venner
    På AN sine Kit har du vel denne muligheten.
    Ang. div annet, så sender jeg deg PM....etterhvert. ;)
    O.J.B
    Audio notes venner
    Pye skrev:
    Må vel for all del melde meg på i AN's sine venner! Seint er bedre enn aldri... *S* ;D
    //P
    Og der var mesterkokken på plass og! ;D Velkommen skaldu være :D
    Rune S
    Audio notes venner
    BHO skrev:
    Hiv ut 6X5 og skaff deg en BP-PSU.... :D ;)
    Har du sammenlignet? Kan du utdype litt hva du eventuellt mener blir bedre "lydmessig" ?
    Hadde DIY Hifi Supply TRAM forforsterker,og den strømforsyningen er nok temmelig lik det BP gjør.5U4 likeretter - choke -10uF kondis- motstand-150uF kondis-motstand- 150uF kondis .
    rune
    JanR
    Audio notes venner
    Gammel annonse desverre.
    Nå er ikke den kællen særlig kjapp til å svare heller.
    Sendte den første mailen i oktober-november.....
    Fikk svar i tidlig januar at " den er holdt av til en norrmann....bla bla...."
    Men prisen er absolutt levelig ;)
    /jan
    JanR
    Audio notes venner
    Absolutt en bra pris på M2'n.
    Det er en knallbra pre i mine ører.
    Meishu,latterlig billig selv om 30k er dyrt for meg.Koster vel det 3 dobbelte ny ?
    /jan
    rolfozzy
    Audio notes venner
    Hvor mye står danskekrona i for tiden ?
    Hva blir det i frakt fra Danmark ?
    JanR
    Audio notes venner
    8000 DKR = 8574.4 NKR
    Frakt...fan vet,sende poste restante til Strømstad om mulig.
    Akkurat Meishu (om det hadde vært aktuelt) hadde jeg selvsagt hentet.
    Litt OT: du drar i morgen ?
    /jan
    JanOlav
    Sandefjord
    Audio notes venner
    /jan
    Porto kan vel ikke være så volsomt mye, 2-300 kroner?
    JanR
    Audio notes venner
    Pengvim skrev:
    Men så har vi jo en kvise på samfunnets rumpe... Tollvesenet! :(
    Flere måter å gjøre det på.
    En er som sagt å sende til Strømstad (for oss i Østfold) poste restante.Fungerer bra for meg ::)
    rolfozzy:
    Jasså,blitt skikkelg bitt av AN basillen nå ;D
    /jan
    rolfozzy
    JanOlav
    Sandefjord
    Audio notes venner
    rolfozzy skrev:
    Continuo skrev:
    rolfozzy skrev:
    JanR skrev:
    rolfozzy skrev:
    Ja. Fly fra Gardemoen 11.45.
    Ok,god tur :)
    /jan
    Takk :-\ Jobb, jobb og atter jobb.Men det må til for å få noe nytt i kjellern.
    Kanskje noe mer AN.
    AN er det verdt og jobbe litt for! ;) :D
    Tja. Vet ikke om alle er enig i det. Regnskapsførern er ihvertfall ikke enig.
    Regnskapsføreren skal du gi faen i.
    patro
    Audio notes venner
    /jan
    Ja, det var en tålmodighetsprøve å kjøpe dac av svensken. Dessuten er Bussgods i Sverige noe av det tregeste jeg har vært borti. Ennå er den ikke i hus, men snart blir det tur til Charlottenberg for å hente vidunderet. Så får vi håpe den er i stand, da...
    Den er fra ca 2000 - kan jo like godt spørre om forslag til røroppgradering med én gang - er det noen komboer som har vært særlig vellykket? Er forøvrig veldig fornøyd med RCA black plates i M2!
    patro
    JanR
    Audio notes venner
    patro
    Jeg bruker Mullard gold pin i min Dac1.(NOS rør) Min er fra 95 så ikke sikkert at de er helt identiske.
    Bruker 2x 6922 rør.
    Testet JAN Philips (nye) og Sylvania.Mullard var uten tvil best hos meg.
    RCA fikk jeg aldri testet men har litt tro på at de kan fungere greit også.
    Du får ta noen bilder når den er i hus.
    Skulle du mot formodning kvitte deg med den så skrik ut ;)
    Vil du prøve Mullard 6922 så si i fra så kan du få teste det ene settet jeg har "extra".
    /jan
    JanR
    Audio notes venner
    Da var dac1 ferdig :)
    Blir sendt fra UA i dag eller i morgen tidlig.
    Takker Olof/Lars Erik,bra jobba guttær.
    /jan"somgledersegsomenunge"olsen
    rama
    biskopen av holmlia
    oslo
    Audio notes venner
    grattis, jan.
    men hvorfor kjører du ikke til tønsberg og henter den i stedet for å legge siste etappen i postens elefanthender?
    JanR
    Audio notes venner
    joaquin skrev:
    grattis, jan.
    Blir mye kjøring,sliter litt med tid også.Planen var å fixe den på lørdag men ble snaut med tid så vi dro hjem.Må i så fall vente til helgen og det går jo ikke an !
    Gutta pakker så godt inn og blir sendt som bedriftspakke så stoler på at det går bra.
    Men en ting er sikkert,det blir flere turer til UA ;)
    /jan
    JanOlav
    Sandefjord
    Audio notes venner
    JanR skrev:
    joaquin skrev:
    grattis, jan.
    /jan
    Ny?
    Grattis!
    JanR
    Audio notes venner
    Stoler på at problemet er løst en gang for alle.
    Skal bli godt å få "barnet" hjem igjen ;)
    /jan
    OivindJ
    Audio notes venner
    /jan
    1.1x Signatur pluss ?
    Noe slikt i tankene? Ser jo veldig spennende ut den.
    JanR
    Audio notes venner
    Lever i "the dark ages" ennå jeg,liker gammelt skrot som Dac1 bla ;)
    Syns den hevder seg meget bra alderen tatt i betraktning,veldig musikalsk liten rakker.
    Men gutta har sørget for at den skal fungere smertefritt her hos meg i lang tid fremover.
    På sikt...hvem vet,en 2.1 hadde ikke vært å forakte.
    /jan
    patro
    Audio notes venner
    Bruker 2x 6922 rør.
    /jan
    Takk for tips om Mullard, Jan. Og ikke minst forslag om lån... Det var hyggelig! Du skal ikke se bort fra at jeg tar deg på ordet!
    Har kikket litt på andre poster, mange anbefalinger på disse rørene. For eksempel:
    http://www.hifisentralen.no/forum/index.php/topic,6009.0/all.html
    Samt en ganske inngående side her:
    http://home.att.net/~chimeraone/6dj8sound.html
    Men dette er sider som sikkert tenker rør til forsterkere først og fremst, men kan man ha som regel at gode rør for forsterker = gode rør for DAC?
    Håper jo at Dac'en blir enden på innkjøpslista (det begynner å klinge hult i kista) men skal absolutt tipse her hvis jeg ikke beholder den...
    JanR
    Audio notes venner
    Tror nok du beholder dac :)
    Rør ja,mere nøytrale rør så hadde jeg nok vurdert JAN Philips,koster ikke rart.
    Siemens gold pin får man vel tak i til en levelig pris også.
    Mullard er noe dyrere men låter i mine ører f* så mye bedre.
    Bare skrike ut så sender jeg det ene settet med Mullies til deg så får du testet iaf,blir de for "feite" for deg så prøver du noen andre.Billigere enn å kjøpe en haug med rør.
    RCA skal jeg få testet så snart dac er i hus.Kommer tilbake til deg med en liten "rapport" i løpet av ett par dager eller så.Har tro på de også ;)
    /jan
    JanR
    Audio notes venner
    Og da var min gamle dac1 på plass igjen i stua og funker veldig så bra ;D
    Får besøk i kveld så satser på at problemet er løst.
    En stoor takk til UA gutta for at de stiller opp i tide og utide.Bra jobbet :)
    /jan
    Audio notes venner
    Supert at ting ordner seg Jan.
    Driver med litt "tuberollin" ikveld på mine AN blokker. Ganske interessant. Sist jeg gjorde det hadde jeg andre høyttalere. Nå ser det ut for at en annen rørsammensetning spiller bedre. Ihvertfall ganske anderledes.
    JanR
    Audio notes venner
    Ting ordner seg alltid for de snille gutta ;D
    Når sant skal sies hadde dac'en ett par "rapptusser" etter ett par spilte timer...
    Ett par kjappe av-på slåinger så hjalp det,vært i kjempeform i hele kveld.
    Gått i litt OTO og 2A3 i kveld,har savnet dac mere enn jeg trodde.
    Appropå rør ja,i mangel på pre så kjørte vi 2A3 rett i dac,hev ut EH 6SN7 gold pin og og inn med Mullard ECC33...du milde så morro det ble plutselig ;D
    /jan
