Kunne disse egne seg godt til midbass/nedre mellomtone i åpen fjøl? 150 hz til 300-350 hz.
Faital Pro 18 HP 1040 A
Nominal Specifications
Nominal Diameter 18", 460 mm
Overall Diameter 18.11", 460 mm
Bolt Circle Diameter 17.32", 440 mm
Baffle Cutout Diameter 16.61", 422 mm
Depth 7.95", 202 mm
Flange and Gasket Thickness 0.55", 13.9 mm
Electrical Specifications
Minimum Impedance 6.6 Ohm
Nominal Impedance 8 Ohm
Nominal Power Handling*** 1,000 W
Maximum Power Handling**** 2,000 W
Sensitivity (1W/1m) 99 dB
Frequency Range 38 - 2500 Hz
Voice Coil Diameter 4", 100 mm
Winding Material Aluminium
Former Material Glass Fiber
Winding Depth 0.9", 23 mm
Magnetic Gap Depth 0.47", 12 mm
Flux Density 1.3 T
THIELE & SMALL Parameters
Resonant Frequency (fs) 38 Hz
DC Resistance (Re) 5.5 Ohm
BL Product (BL) 24.5 N/A
Diaphragm Mass inc. Airload (Mms) 163 grams
Mechanical Compliance of Suspension (Cms) 0.11 mm/N
Rms 4.42 Kg/s
Electromagnetic Q (Qes) 0.35
Mechanical Q (Qms) 8.75
Total Q (Qts) 0.34
Compliance Equivalent Volume (Vas) 7.37 ft³, 208.8 dm³
Surface Area of Cone (Sd) 180.7"², 1,166 cm²
Maximum Linear Excursion (Xmax)* 9.5 mm
Xdamage** 17.5 mm
Coil Inductance (Le) 1.36 mH
Diaphragm mass (Mmd) 141 g
Eta Zero 3.14 %
Depth 7.95", 202 mm
Flux Density 1.3 T
Rms 4.42 Kg/s
Total Q (Qts) 0.34
Xdamage** 17.5 mm
Eta Zero 3.14 %
