Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • Balle Clorin
    Det som er sikker er at den virker!! Får man litt lengre avstand mellom kablen i kabalsalaten blir det mindre "smitte" overført. Men om det har en praktsik betydning er noe helt annet...
    Groove
    Det er videnskabeligt bevist at det virker. Hvis du tror på det virker, gør det det...og så er alle jo glade 😁
    Og hvis du skriver positivt om dem på nettet får du 20% rabat (y)
    Eirik84
    Drammen
    Hvem trenger å stabilisere kablene sine?
    Kun ca 15k pr. stk. Dess fler dess bedre selvsagt.
    Noe for strøm/emc/stråling fantasten(e).
    Mye snacks hos cableco - mulig disse har vært linket ut før men Quantum-klistremerker var ny for meg
    Telos Audio Design Quantum Sticker
    At present, all TELOS electronic products have been integrated with Quantum X2 technique; on printed circuits boards' insulation, electronic parts to eliminate electrostatic discharge and improve on the components' efficiency and overall Hifi system performance
    All Quantum Stickers products are suitable for all audio systems and can be easily applied. By applying the Quantum Stickers at cable interconnect sections, IC chips, capacitors and resistors, this quickly allows worldwide audiophiles and music lovers to experience the advantage of Hifi tuning with ease. Comparing the Quantum X2 with the current tuning products available on the market, Quantum X2 can easily improve your Hifi and home theatre system, helping them reached their optimal performance.
    Every Quantum X2 sticker contains patented formula infra-red powder (which undergoes 36 hours of cryogenic process at -196oC), patented formula negative ion powder, titanium dioxide photocatalyst materials, silica wafer insulation coating material, pentoxide antistatic agent material, calcium oxide CAO desiccant material, zironia filter material and alumina structural ceramic material
    Official test reports from SGS proves that Quantum X2 exclusive formula is not harmful to humans as it is unleaded and free from highly polluted elements
    ymir
    Vel de selger og sier hva produsenter av emc absorber sheet sier,men så er det prisingen da.
    De aller fleste store produsenter lager og selger slikt,og mye annet "morsomt" innen for emc kategorien.
    At noen selger overpriset emc materiell fra de store fabrikanter til hifi markedet betyr ikke det at produktene ikke fungerer som tiltenkt.
    Bare å søke på EMC absorber så dukker det mye "morsomt" opp.
    Hvilken emi skjerming tror dere Supra bruker?Kobber?
    Applications
    • RFID (Radio Frequency Identification) systems
    • NFC (Near-field communication)
    • Wireless power chargers (WPC / Qi)
    • Computers (NB / Desktop / Tablet) and peripherals
    • Digital Products
    • Mobile phones / Smart phones / Phablet
    • Wireless equipment
    • EMI-shielding box / Dark box
    • Between printed circuit boards
    • On ICs, processors, and controllers
    • On cables that need high flexibility
    Her er jeg i villrede.
    Noen som vet hva fordelen med dette er?
    motoren
    Flekkefjord
    Det er nok ikke noe annet at det er noen som vil tjene penger, masse penger på lettlurte
    ufo
    paul hører forskjell med kabelløftere på høyttalerkablene :D
    Loudspeaker Rubbing Device - for å rette inn nanokrystallene!
    PeriodeLytter
    Dette tror jeg gjerne på. En metode ofte benyttet for å lage "god lyd" er minimalistisk design hvor det som vanligvis ansees som helt nødvendige filter utelates til fordel for bedre lyd. Om forsterkeren ikke har filter på utgangen kan høytalerkabel ta funksjon som filter, men samtidig også fungere som antenne som kan sende støy tilbake i effekttrinnet.
    Og for alle som har montert og justert dipolantenner (2 parallele lednigner) vet hvor stor forskjell selv små justeringer kan utgjøre i enkelte tilfeller.
    En må gjerne konkludere med at et system hvor slike kabelstøtter gir bedre resultat muligens ikke bare er high resolution, men også har et grunnleggende problem som behøver plaster :unsure: Da kan det like gjerne gi enda bedre resultat ved å gjøre høytalerkabelen 127 mm kortere, eller 53 mm lenger. Hvem vet hvor mye paster som behøves. Det er jo derfor dette er jækla moro :rolleyes:
    X
    X186841
    Som jenta sa: Det er da mye bedre uten snabelfilter! Men det kan fort få uønskede konsekvenser:)
    Snickers-is
    Vis vedlegget 673140
    Disse motorene er litt spesielle. De har ikke noe stål i seg, så selve magnetene befinner seg få millimetere fra spolen. Neodymmagneter er svært følsomme for varme, og disse spolene er ikke veldig store, så her gjelder det å kvitte seg med varmen fra spolen og kjøle magnetene.
    Hvor stor effekten av sølv vs kobber er når man forsøker å kvantifisere effekten vet jeg ikke, men sølv er utvilsomt en formidabel varmeleder. Man ville trolig hatt betydelig effekt av å ribbe utsiden av sølvringen også.
    JMM
    Slava Ukraini!
    Fredrikstad
    Om kjøling er tingen så ville vel en ring i kobber med kjøleribber være langt mer effektiv enn en solid ring i sølv, gitt økningen i overflateareal. Sølv med kjøleribber ville vært enda litt mer effektivt, men relativt marginalt siden økningen i kjøleareal betyr langt mer enn den lille forbedringen i varmeledningsevne fra kobber (401 W/(m·K)) til sølv (429 W/(m·K)).
    YesJens
    Musikkelsker og Livsnyter😊
    Under stjernene
    Trudde poenget med kabekløftere var å unngå påvirkning fra statisk elektrisitet🏋️‍♀️
    JMM
    Slava Ukraini!
    Fredrikstad
    Og vibrasjoner. Elektronene liker ikke vibrasjoner må vite.
    AOC
    Men det er jo superviktig at kabelløfterne holder kablene 100 % vannrett hele veien. Om ikke så vil lyden hope seg opp og gå saktere der kabelen peker oppover og til slutt stange i kø, og rett etter kabeltoppen vil lyden 'rutsje' nedover, med myyyYYYyyye tynnere lydbilde. Aller helst bør man ha kabelløftere som gir kabelen en svak helning NEDOVER hele veien, men pass på; FOR mye helning vil skape et vakuum i forsterkeren, med katastrofale følger for lyden og ikke minst sikringen som overbelastes, ettersom strømmen suges gjennom den med et enormt vakuum. Det er derfor 16A sikringer låter bedre enn 10A-sikringer. Eventuelt kan dette løses ved å stikke små hull i kabelene nær terminalene på forsterker slik at undertrykket i kabelene utlignes mot atmosfærisk trykk i omgivelsene, men også her skal en være ytterst nøyaktig i lyd-tuningen av kabelen, all den tid disse trykkutjevningsåpningene i kabelen vil gi blåselyder på samme måte som en feildimensjonert port i en subwoofer pga elektroner på avveie, og elektroner på avveie vil vi ikke ha, tro meg!
    Bruk kabler til å "tune" lyden.
    Ikke eq, dsp, kilde, forsterker, HT, rom, akustikk etc. men kabel er løsningen.
    Aurora
    Ytterst i havgapet...
    CA 30 kr /stk for "tuning" pluggene er nå ikke all verden til pris, men himmel og hav for ei bøtte med pisspreik.....
    HasseBasse
    Hjortshøj, Danmark.
    Gummitylle med plastikskrue "insert" :LOL:.... Ja, verden er af lave.... HiFi-verden i hvert fald..... for pokker da o_O
    Funksjonen er nokså opplagt. Ved å skru plastskruen litt inn eller ut endres diameteren på gummidingsen, og avstanden mellom enkeltledere i de løst flettede kablene endres med noen brøkdeler av en millimeter. Det vil i sin tur gi en mikroskopisk økning eller reduksjon i kapasitans og induktans i kabelen. Litt større avstand mellom pluss og minus gir høyere induktans og lavere kapasitans, og motsatt. Det gir en analog eq med max utsving på kanskje +/- 0,01 dB forskjell i avrulling ved 20 kHz. Effekten er reell, men så liten at den ikke har noen som helst betydning.
    PeriodeLytter
    Jeg undrer mest på hva som var inspirasjonen til dette produktet?
    Floke i kabelkassen med masse rusk og rask sittende fast i kabelene? "Kan jeg selge denne dritten montro?"
    Eller var det under en strikkeklubbmøte at man fant at man ønsket en minimum avstand til andre paralelle ledere? Om det er siste tørr jeg påstå det må finnes bedre og mer holdbare metoder til å løse dette på.
    PeterDa
    Minhus
    Trestubbe med to bananplugger eller noe som virkelig gjør undrer.
    Blitt tatt fram noen ganger. (forrige generasjon) Er bare en et kostbart Zobel filter.
