FRANCO SERBLIN "THE MASTER IS BACK"
  • sound of heaven
    After three years of research and development, LIGNEA,
    one of the last projects conceived by Franco Serblin, has become a reality.
    During all the steps, I always followed his teaching and his
    “modus operandi” for every single detail.
    Today I wish to affirm that the value we give to things
    is the meaning we put in them
    The value I attribute to the LIGNEA
    project is the profound esteem I always had for Franco.
    Massimiliano Favella
    sound of heaven
    The wood chamber has a special refraction construction allowing for better
    control of resonances
    sound of heaven
    Her er Ken Kessler utsagn etter å ha besøkt standen til Massimiliano på messa i Munchen.
    Tragic, this: the last ever design from Franco Serblin, founder of Sonus Faber. Called Lignea, it blew me away, a svelte floorstander delivering bass that it simply should not be able to reproduce from a 110mm woofer, below a 27mm tweeter. As you`d expect , it`s so pretty that it will make you cry, and price is circa 4000-5000 Euro. Cia, Franco.
    Prisene på modell Lignea blir 40.990.- for high gloss wood og 41.990.- for medium gloss graphite finish.
    Holmium
    Sliter med utseendet til Lignea, får håpe de låter bra.
    grammofon
    Sliter? Spiller du ikke lutt eller mandolin eller noe sånt? :)
    Kona vil avgjort like dem. Men hun gir blanke i lyden.
    sound of heaven
    WHAT’S NEW
    The Lignea from Franco Serblin
    The late Franco Serblin, the man responsible for Sonus faber is no longer with us to design great speakers, but his son in law, Massimiliano has brought the last of this Italian master’s vision to fruition.
    Here at TONEAudio, we have the absolutely lovely Lignea, a diminutive floor standing speaker that retails for about $5,000 US. Watch for our full review in issue #81. Think of the Lignea more as a mini monitor with an elegantly integrated stand. There is no low, low bass response to speak of, but like your favorite Brit mini monitor, you won’t miss it.
    Check out the rest of Mr. Serblin’s creations here:
    http://www.francoserblin.it
    Kolschtat
    Torshov
    Accordo er så pene at ytelsen havner i andre rekke.
    Lingea derimot, pen som den er, ser vettskremt ut..
    Auditor
    Det er en grunn til den formen, Kolschtat. Franco bygde- og konstruerte- høyttalere som de elektrodynamiske musikkinstrumenter de bestandig har vært..
    Distinctive
    Problemet er vel at høyttalere skal være minst mulig musikkinstrument (feks. kasseresonans).
    Kolschtat
    Torshov
    Det betviler jeg ikke, men hva angår estetikk ser de fortsatt ut som de så noe de ikke var klare for. Estetikk og god lyd går nødvendigvis ikke hånd i hånd; er JBL DD6700 vakker, tja, til en viss grad, men det er også den beste kommersielle høyttaleren jeg har hørt. Videre, jeg digger også Tannoy, som overhodet ikke ser ut som det høer hjemme i 2016, men det spiller bedre enn det meste.
    Jeg er innforstått med at dette er en Franco-tråd, poenget mitt var kun at Accordo ser ut som en million, Lingeea derimot...
    Auditor
    Distinctive, Kolschtat: Hvordan tror dere et akustisk instrument får klangen sin? Resonnanser er ikke negative hvis de brukes på riktig vis. ALLE instrumentprodusenter , teknikere og akustikere vet det.
    Kolschtat
    Torshov
    Men kjære fru Brundtland; skal høyttalere gjenskape lyden eller virke som en videre forsterkning av den klangen instrumentet opprinnelig hadde? I din verden er det tydeligvis slik at kun vettskremte fioliner kan gjenskape fioliner..
    sound of heaven
    Franco Serblin Accordo i samspill med Audia Flight FLS 10 fra Melbourne International Hi-Fi Show 2017;)
    Trane
    Evo III
    Hertugen
    Hjemme
    Det kommer an på rommet fant jeg ut :) prøvde de begge veier.
    Det som funket best her var litt ut i rommet,ca en 1/2 meter i fra sidevegger.
    Omvendt i fra det som står i boka,da låt det utrolig flott.
    oyvjorge
    Akershus,Vestby
    Hos meg funker det best med Åpningen ut i rommet. Hadde jeg åpningen inn mot veggen trigger det den peaken rommet har ved ca 100-200 hertz. RES skrev en anmeldelse hvor han skriver noe om det.
    oyvindl85
    Jeg fikk best plasseringsresultat ved å vinkle dem nokså kraftig innover. Krysser foran lytteposisjon.
    Jeg sitter ca 3.5 meter unna høyttalerne. De stod 270 cm fra hverandre. Målt fra bakre ytre hjørne på høyttaleren og til frontvegg var det 57 cm. Fra indre fremre hjørne til frontvegg var det 77 cm. Noe som gav nokså mye toe-in og lyden falt på plass her hos meg. Snudde man de omvendt fikk man litt bredere lydbilde, men jeg syns bassen ble mer diffus enn når de stod som anbefalt. Diskanten roet seg også betraktelig ved denne plasseringen. Super oppløst, men ikke frempå.
    Har ikke disse lenger selv, dessverre. Men man skal ikke se vekk fra at det blir slike en gang i fremtiden igjen. For de er fantastisk gode når man får plassert dem. Er vel disse høyttalerne jeg har måtte jobbet mest med for å låte «optimalt»
    sound of heaven
    Hei alle venner av Franco Serblin høyttalere.
    Dere som har lest den glimrende testen av Accordo i siste HI-FI News fikk med dere at det ble nevnt en fjerde modell. Kan nå bekrefte at det er snakk om en gulvstående modell som vil legge seg mellom Accordo og Ktema. Forhåpentligvis vil den nye modellen bli klar for markedet i løpet av 2018.
    Sound of Heaven
    Holmium
    Sound of Heaven
    Noe nytt vedrørende ny modell?
    oyvindl85
    Passe tilfeldig plassert der det var plass foran Spendor.
    Spiller allikevel latterlig bra!
    Vis vedlegget 506699
    Vis vedlegget 506700
    Kjøpte du nettopp disse nordafor? Da er det mine gamle :) Var forresten på tanke å kjøpe dem tilbake. Men har jo mine Dynaudio C1 Signature. Så fornuften tok meg, denne gang :) Accordoene låter fantastisk godt. Men for å spille optimalt MÅ de plasseres riktig. Så lov meg og deg selv og prøv deg frem. Hos meg ble de best med mye toe in. Men ser de står nokså skrått innover på bildene. Med gode innspillinger gir disse gåsehudfaktor. Grattis :)
    Holmium
    Stemmer det :)
    Er glad i en del toe in selv, ikke rukket prøve ut så mye plassering enda. Bli litt kjent med dem først så er det enklere å merke forskjellene ved endret plassering.
    Holmium
    Takk for det.
    Blir spennende å se hvilke som blir værende. Skulle hatt flere oppsett :cool:
    Holmium
    Hvilke forsterkere har dere benyttet på Accordo?
    Cato G.
    Et nytt medlem i menigheten?
    Hei!
    Har hatt Accordo på hjemlån i noen dager nå, og kan bare slutte meg til gjengen av beundrere. Jeg spiller mest klassisk, mye sang, og Accordoen spiller helt fenomenalt. Men, den spiller dægern døtte meg veldig bra på annen musikk også: På Jan Garbareks "Visible World" er det to spor: "Red Wind" og "The Survivor" hvor man kan høre Marilyn Mazurs perkusjoner i all sin prakt, og selv om Accordoen ikke går så dypt som en fulltone, gjengir den basstrommene på en veldig naturtro måte (som om det var en veldig god lukket konstruksjon). Også Melody Gardot og Weather Report ("Gibraltar") høre helt fantastiske ut!! Jeg spiller på Audio Research REF 5SE og Reference 150 sluttrinn (med Yter høyttalerkabler!!), og kan opplyse at det er en aldeles fremragende match!! Tror de som har gode rørtrinn burde ha Accordo øverst på lista! Selv kunne jeg nok aller helst tenkt meg et par Ktema, men de er vanskelige å få lyttet til, men jeg jobber med saken!!
