Linn Lp-12
  • FZ
    Bra beskrivelse av Radikal/DC-motoren sakset fra ThomasOK på Linn-forum:
    Some good posts on here (on both the Keel and the Radikal). If you put together the info from Colin's informative post with that from The Flatearther you will get most of the reason for the superiority of the Radikal. Here are a couple of other things worth pointing out.
    One big advantage of the AC motor is that it is a Synchronous device meaning it is synchronized with the AC line frequency so its rotation is quite accurate and free from drift. The big advantage to it initially, as can be seen from the earliest LP12s (not to mention most current Regas and any number of other turntables both current and historic) is that it requires NO control circuitry to keep a steady speed as the line frequency keeps it in line. However, it does pick up noise from our ever noisier AC power lines which translates into more vibrations and it is true that it performs with minimal vibration at relatively low voltages but ones low enough they would have a hard time starting the turntable. (Note that Nottingham Analog overcomes this problem by having you spin the platter to start the turntable and holding the platter to stop it as it doesn't have enough torque to start itself. Hence they have no on/off switch - not that elegant but it works for them.) When the LP12 came out this was the best way to insure speed accuracy as the servo controls of the time (and the vast majority even now) had musically deleterious problems.
    Over time Linn developed the Valhalla and then the Lingo to filter out AC problems, ensure even more accurate frequency control of the motor, run the motor at the voltage where it had the lowest vibration combined with enough torque to overcome the friction from any level of groove modulation and to allow convenient switching from 33.3RPM to 45RPM. The Lingo 2 and 3, while musically improved over the original Lingo are essentially the same design but with the improvements brought about by going to a mainly surface mount layout and some other fine tuning.
    So it is easy to see the reason the AC motor was used initially (and why it is still used by very many others) and why Linn continually developed improved ways to drive it.
    Brushed DC motors, such as the one Linn uses, have the advantage of not having a fluctuating magnetic field as bot AC and brushless DC motors do. So one of the immediate advantages is getting rid of this fluctuating magnetic field, and its effects on the cartridge - which is basically a magnetic vibration sensor. But a number of things needed to be improved from early DC motor technology to make it really useable by Linn. As Colin mentioned one is the ability to run the motor slower to reduce vibration and allow the larger pulley to beter control the belt. I have seen a number of other DC motor turntables from companies like Teres, Origin Live and others as well as "upgrade" motors from OL and they all have pulleys about the size of a pencil. But another problem with brushed motors is that the brushes wear out. Having a life of three or five or seven years was just not acceptable to Linn. Third is the problem of maintaining constant short and long term speed. This is one of the detriments to a DC motor system in that the speed is dependent on the voltage applied. Send more voltage and it goes faster, send less and it goes slower. Other companies have used various methods from servo controls to batteries and I have found none of them to product a musical performance at the level of the AC motor LP12. Servos, with their constantly hunting for the proper speed tend to blur the pitches and render the fine musical nuances harder to hear. Batteries get rid of that problem but have to be regularly recharged and those I have seen have noticeable drift. The worst are the motor drive systems I have seen from Origin Live which drift so bad you can notice that the pitch is off within a single track! This observation comes from similar OL drive systems in three different turntables including an LP12 and an Origin Live table.
    So how has Linn overcome this problem? First off for the motor Linn worked with Maxon, considered the pinnacle of DC motor manufacturers, to come up with a low speed, very low vibration and long lasting DC motor. Part of the solution is that the brushes are precious metal and so should last 20 to 30 years of normal usage. And, as mentioned, they have a motor that runs at a speed that allows the pulley to be the same size as on the AC motor. But then Linn takes that motor and surrounds it in a vibration absorbing plastic foam and fits that into a custom machined outer sleeve and mounting fixture of a dense and hard but vibrationally dead plastic material. This motor and mounting system allows very smooth rotation with minimal vibration and again the elimination of the fluctuating magnetic field. The complexity of the motor and its mounting system can be hinted at by the difference in price between the cost for the replacement motors: in the US approximately $170 for the AC and a bit over $1400 for the DC!
    But the motor by itself still isn't free from drift - this is where the control system is needed. Linn investigated the alternatives such as battery drive and other simple voltage control circuits and found it virtually impossible to meet a worst case drift target of under .1 percent. But again existing servo systems, which often measure and adjust speed 50 or 250 times per revolution, had unacceptable musical deficiencies as well. So Linn developed a unique control system for the Radikal - a very slow servo. Linn took an extremely accurate clock circuit, from the same family as that used to clock the digital data in the Klimax DS, and use it as a reference. Then they developed an optical sensor system using an infrared LED and an optical sensor to read the speed of the platter and compare it to the clock. Any difference is adjusted by sending more or less voltage to the motor to correct the speed. So far this is similar to most servo systems although the use of the optical sensor may be unusual and the accuracy of the reference clock is certainly well above what others have used. But the devil is in the details, and that is where Linn's system is brilliantly different. Since the main speed problem of a motor as good as Linn is using is not short, quick variations but long term drift, Linn made the servo operate very slowly. The optical sensor only measures the rotation speed of the platter once per revolution so it also only corrects once per revolution. So the constant, quick fluctuations of speed the typical fast servos have are missing from the Radikal. And even the way the sensor works is quite clever as it really doesn't care about the exact placement of the little light-absorbing felt strip as long as the light is interrupted once per revolution it knows what it needs to know. Furthermore, the servo system is designed such the maximum speed change it will make in one revolution is .03%. Yep, 3 hundredths of a percent! Anyone have pitch that perfect? So if the speed were wrong it would take quite a while for it to correct itself hence the recommendation to run the Radikal for 10 minutes on first installing it so it can calibrate itself. Also the reason the dealers have a strobe LED that plugs into the Radikal power supply to verify correct speed with the Linn speed checker disk. But since you don't want to wait 10 minutes for calibration every time you play a record Linn also built in a memory. Every time you turn the LP12 off from the turntable mounted switch the Radikal stores the last voltage setting used. When you turn it back on it starts at the same setting and continues to monitor the platter rotation and fine tune as necessary. This system is what allows the motor to maintain exceptional speed accuracy and timbral purity while the very low vibration motor and the lack of the fluctuating magnetic field means that the cartridge has much less interference in its ability to turn the vibrations engraved in the grooves into electrical signals via a magnetic vibration sensor system.
    So this is why this system wasn't used 40 years ago - the technology literally wasn't there. And despite the fact that Linn has done it and made this huge stride forward in musical performance you don't see everybody out there copying it because it is difficult to achieve and required a tremendous amount of R&D to accomplish (not to mention Linn likely have patents pending or granted on the technology).
    Will Linn adopt a yet different drive system 35 years from now? Who knows how technology might change and materials science could improve by then? But I think it is safe to say that Linn evaluated all the possible drive systems available currently. And they obviously evaluated them not just for their performance as currently used but for their POTENTIAL performance if they were developed beyond what others were doing. Personally, I'm just glad they spent the time and energy to develop the Radikal as it has literally given me a whole new record collection and brought the musicians and their musical message more forcefully into my room. If they can make another such substantial improvement in 5, 10, 20, or 30 years I say bring it on! (and just hope I can still hear it then).
    [HR][/HR]
    FZ
    Kom over en tråd hvor det ble harselert over at noen (det er faktisk ganske mange av oss) påstår at de hører forskjell på sidene av filtmatta på LP12. Det jeg reagerer på at det ikke er mulig å svare på innlegget.
    Legg det inn her så skal du få svar.............
    K
    Kleine Freiheit
    Ikke at det har noe med akkurat hvilken filtmatte som er best (det har jeg ikke noe forhold til), men jeg synes at det er merkelig at et medlem på forumet har fått sitt eget underforum hvor det ikke er mulig å poste svar.
    Hvis andre medlemmer tester utstyr, eller har meninger om produkter ser det ikke ut til å gjelde samme regler for de. Hvorfor?
    Bollis
    arnejustad
    Kan man ikke få tatt en måling av hver side, så har man litt mer enn ord mot ord?
    Kunne jo vert interessant uansett hvilken mening man måtte ha, men er jeg.
    FZ
    Hva slags måling tenker du på? Man kan jo se at det er forskjell på sidene. Og noen av oss kan høre forskjell også :)
    Linn skriver ingenting om at det er forskjell, men jeg har snakket med et par ansatte på Linn og de er også helt klare på at det er bedre lyd med den riktige siden opp............
    Griffenfeldt
    I en blokk
    Jeg registrerte hos EspenL at hans filtmatte og min ikke er like. Hans matte virker tynnere enn min? Medfører det riktighet?
    Audiophile-Arve
    Bollis
    Det kan vere greitt også. På www.audiophile.no opna vi for kommentarar til artiklane våre, men det enda med ein masse spam og viagraannonser, og var kanskje medverkande at sidene ikkje fungerte så godt mot slutten.
    Trur artiklar bør kunne svarast på, sånn reint prinsipielt, men det er mykje arbeid å røkte påfylgjande kommentarar når ein skal skilje snørr og bartar.
    arnejustad
    Jeg for min del hører ikke forskjell, men om andre gjør det, ja så gjør de sikkert det. Synes egentlig hele diskusjonen begynner å gå litt i repeat.
    Dersom man måler lyden man får ut av høytalerne på hver side av matten, kan man ikke da vise til beviselige forskjeller?
    FZ
    Det er riktig. De nyere mattene, fra en 4-5 år tilbake, er tynnere enn de eldre. Og de tynnere låter klart bedre. Men som nevnt tidligere er det også lydmessig forskjell på matter av samme årgang, selvom de ser helt like ut.
    Enig i at dette er repeat og det står en masse om dette tidligere i tråden. Det som trigga nå er at noen skal kunne legge ut en tråd som harseler med oss som mener å høre forskjell uten at det er mulig å kommentere på tråden. Det blir for sært, høvding.....
    Og som kommentar til A-A: Det er himmelvid forskjell på en LP12 med Akito/Basik PSU og en med Ekos SE/Keel/Radikal og selvsagt mye tydeligere å høre nyanser mellom f.eks. sidene på matta, støvlokk nede/oppe/helt av og posisjon av rem.........
    FZ
    Et par hundre tenker jeg.........
    Fulgte med matte da jeg kjøpte ny tallerken i 2008 og 2010, så jeg er ikke sikker på hva de koster.
    arnejustad
    Er helt enig. Når man utfordrer noen til å høre forskjell uten å tillate folk å svare, blir det for dumt.
    Nå skal ikke jeg påstå det ene eller andre, men en blindtest hadde jo vert artig. Kunne du fått litt assistanse til å gjennomføre en blindtest FZ?
    Om resultatet går den ene eller den andre veien vil jeg tro folk her på sentralen vil ta deg på ordet.
    FZ
    Jeg har allerede gjennomført en blindtest. Det gjorde jeg i 2008 da Peter Swain var innom og installerte Keel og Ekos SE. Da vi satt langt ut på kvelden og jeg ikke satt i sweet spot , men i en sofa godt til venstre for venstre høyttaler og var opptatt med et eller annet spilte Peter en låt fra Graceland (Paul Simon), var så borte ved spilleren uten at jeg registrerte hva han gjorde og spilte samme kuttet på nytt. Jeg kikket opp og spurte hva han hadde endret siden lyden nå var klart bedre. Det han hadde gjort var å snu matta.
    Satt meg deretter i sweet spot og han byttet igjen 5-6 ganger uten at jeg visste hvilken side han spilte på. Jeg hørte "riktig" side alle gangene.
    Deretter skulle vi merke en annen matte jeg hadde (fra samme årgang) og til min forbauselse låt denne klart bedre enn den første.
    Så blindtesten er gjennomført og det holder for meg.
    arnejustad
    Mitt anlegg vil ikke kunne gi meg samme opplevelse, samme hvor mye godvilje jeg legger til, men jeg tar deg på ordet.
    Ser ingen grunn til at andre, ikke bare kan infinne seg med at dette er ett faktum hos deg til tross for at man selv ikke kan si det samme.
    toriamos
    Hvordan ser det riktige siden ut da? Har hørt på Graceland - har bytta fram og tilbake fire ganger - prøver så godt jeg kan å høre forskjell uten å lykkes.
    Fint om du beskriver hvilken side som skal ligge opp, så skal jeg ta ditt ord for at det er den beste siden.
    FZ
    Hvis du ikke hører forskjell er det vel temmelig uinteressant hvilken side som er "riktig".
    Men uansett, dette har vi vært gjennom mange ganger tidligere og jeg har beskrevet hvordan den siden jeg mener er "riktig opp" ser ut.
    Hvis du leser på Linn-forum er temaet diskutert mange ganger der også. Noen sier de ikke hører forskjell og noen sier de hører det. Forskjellen fra her er at flere av de presumtivt beste forhandlerne merker sidene for kundene om de ønsker det.
    Audiophile-Arve
    Klart at ein meir påkosta spelar vil avsløre ting lettare. Matta mi hadde kanskje flata ut etter snart ti års bruk også, så her er massevis av feilkjelder. Men mitt oppsett var iallfall slik at min høyrsel og persepsjonsevne ikkje avslørte skilnad på sidene. Då meiner eg skilnad. Det er langt lettare å detektere skilnad enn å finne ut kva som er "best" mellom to alternativ.
    Når Rudi ikkje høyrer skilnad på filtmattesidene i sitt oppsett, held eg det som svært sannsynleg at eg ikkje hadde høyrt det der, eg heller. Rudi er svært samvitsfull når det gjeld å få ting til å vere optimale, og han gjev seg ikkje før han er temmeleg sikker på at ting er rett justerte.
    Men dette er ikkje nødvendigvis absolutte sanningar. Einkvar entusiast må gjere sine eigne erfaringar, eventuelt finne ut kven andre ein stolar på. Ei filtmatte er ikkje verste problemet når det gjeld investeringslyst - langt billegare oppgradering enn å kjøpe spesialkablar eller skifte forforsterkar..... Så eg ser ikkje problemet i det heile. Problem dukkar fyrst opp når ein får utsegn av typen "han lyttar på feil side av filtmatta, så då er det ikkje rart han ikkje registrerer skilnaden på bass og diskant".
    FZ
    Det er jeg helt enig i, men har heller aldri sett noen uttale noe i den retning her på sentralen..........
    Uansett, et billig "tweak". Faktisk helt gratis å snu matta og høre om en hører forskjell. Gjør en ikke det er det bare å glemme hele greia, hvis man hører forskjell merker man undersiden så en ikke trenger å gjøre øvelsen på nytt om en har tatt av filten.
    toriamos
    Hva som er interessant for meg får vel jeg avgjøre. Du vil ikke beskrive den riktige siden? Mener at vi ikke har vært gjennom hvordan den riktige siden ser ut.
    ottone
    Min matte er gammel, vet ikke hvor gammel, og ser lik ut på begge sider. Eller kanskje den ikke er original. Hvor ny skal matten være for at sidene skal være forskjellige?
    leon
    Mener å huske at filtmatte du fikk med var ny, ubrukt. Litt usikker, fikk ikke du med kvittering på nye deler ?
    ottone
    Aner ikke. Jeg har aldri tenkt noe særlig på filtmatta, men du har sikkert et poeng. Har vært litt for mye flytting og greier til å ha oversikten på alt sammen.
    Tror jeg må finmyse på matta og teste disse to sidene. Det er utrolig hva jeg hører hvis jeg legger godviljen til.
    FZ
    Da har etterfølgeren til Akiva dukket opp: Linn Kandid.
    Den ser unektelig ut som en Scan-Tech kreasjon og denne gang naken, i motsetning til Akiva.
    FZ
    arnejustad
    Har fått tilbud på en pent brukt Arkiv her og lurer litt på om noen har no serlig erfaring med denne?
    FZ
    Har ikke hørt den, men begynner jo å dra på åra. Kom på markedet i 1992 og i 1987 var det slutt. En stund siden det, men Linn gir vel fremdeles noe i innbytte mot en ny Kandid :cool:
    arnejustad
    Jupp. De gir vel 5k i innbytte tror jeg. Tror forøvrig systemet mitt vil satt pris på 30k i noe anet enn pu, men det hadde jo vert fryktelig gøy å prøvd en Pu i dette sjiktet. Hadde jo Benz LP, men den var såppas håpløs sammen med Linto, at det ble faktisk ganske så mye bedre med AT33ev.
    Vanker det en Kandid eller to hos deg eller?
    ottone
    Interessant.
    FZ, aner du noe om hvordan Linn Kandid vil ligge (lyd) i forhold til ScanTech sine egne, kanskje spesielt Lyra Titan som mange syns den likner ?
    Jeg mener å ha lest at Lyra Titan ligger litt over Linn Kandid i pris, så identiske kan de vel ikke være?
    FZ
    Bruker selv Benz LP i Ekos SE-armen, men laster den med 47k. I Linto med sine 150R blir det temmelig dårlig. Har prøvd å laste Benz LP med 100R og det låter fryktelig trist.........
    Angående Kandid får vi se. Tror nok det i tilfelle blir en god stund til. Har både Benz Ruby2 og LP og trenger vel egentlig ikke en 30kkr PU til akkurat nå :)
    Men låter nok sikkert mer enn brukbart............
    FZ
    Interessant.
    Har ingen aning om hvordan den lyder, men skal bli interessant å høre hva Peter (Swain) sier når han har sammenlignet den med Lyra Atlas og DV's top-of-the-line PU'er XV-1s og t.
    arnejustad
    47K ??
    Finnes LP i flere utgaver eller er det noe her jeg ikke har fått med meg?
    arnejustad
    Ja altså normal mm last, derfor jeg lurte på om den fantes flere utgaver. Tenkte aldri på å prøve 47K med LPén, men neste gang jeg tilfeldigvis får en Benz LP kastet etter meg skal jeg teste ;)
    Rudi
    Ute i skauen i Østfold.
    Ville gjettninger hentet ute i pereferien......... eller ??
    At LP12 kommer med Klimax plinth i hel-frest aluminimum til astronomiske summer.
    At Linn selv kommer til og lage en "billig" arm til entry-level spilleren sin.
    At det kommer en ny "mellom" arm mellom Akito og Ekos SE.
    At det kommer en ny topp plate oppgradering fra Linn.
    At det kommer en ny mellomklasse MC pickup.
    At det kommer en LP12-12" med lengre arm.
    At allt dette kommer i år........ eller ingen av delene..... det er bare og oppsøke spåkonen :cool:
    arnejustad
    De har vel i hvert fall bekreftet at de kommer med en ny entry-level arm som skal erstatte pro-ject på LP12 Majik. Om det skjer i år, skal jeg derimot ikke spekulere i.
    FZ
    Helfrest alu-plinth har jo allerede Linn laget for flere år siden og Ivor har vistnok prototypen. Etter sigende var det ikke noen stor lydforbedring så den ble lagt på hylla.
    Det jeg synes de burde komme med er ny topplate og fjærer med snevrere toleranser.........
