Parks Audio venner
  • knarfar
    Mye nyttig i denne oppdateringen! :p
    Puffin Firmware V1.20
    Changes:
    • Added Magic pop and click minimizer
    • Added Grade which is a record grading function
    • Added DeRumble function (200Hz/12dB)
    • Added RoomEQ function (de-mud cut filter: -6dB Q=2.6 at preset frequencies)
    • Added new clip alerts with asterisk * at Volume (output/DAC clip) & Gain (input/ADC clip)
    • Doubled the Volume settings with finer adj resolution
    • Changed TF to fx. Think like "effects" or f(x)
    • Lowered 2H Tube distortion (7%THD at full signal)
    • Fixed 3H Tape distortion (3.5%THD at full signal)
    • Removed "2H&3H" setting from fx
    • Moved Noise to fx (PinkNoise)
    • Updated Levels to include tenths dB resolution for azimuth adjustment
    • Added Out function and merged SPDIF code, though Out:SPDIF is disabled on non-modded Puffins
    • Lo filter changes: 5Hz, 10Hz, 15Hz, 20Hz, 25Hz (default), 30Hz, 35Hz, 40Hz, 45Hz, 50Hz, 70Hz, 100Hz, 200Hz, & 400Hz
    borglein
    Like greit, er en enkel modifikasjon hvis du skulle få bruk for digitalutgang. Du må komme med lytteinntrykk når den har kommet i hus.
    Ja, jeg ser ikke helt behovet for min egen del. Skal komme med inntrykk når den tid kommer. Moro at det begynner å bli noen av disse i Norge.
    Skal for øvrig bruke den med Dynavector 20x2 low så spent på hvordan støyen blir.
    borglein
    Noen som har forsøkt å justere azimuth ved hjelp av Puffin?
    BeetleBug
    Ja. Det fungerer utmerket å følge instruksene for azimuth justering:
    𝗔𝘇𝗶𝗺𝘂𝘁𝗵 & 𝗙𝗶𝗻𝗲 𝗕𝗮𝗹𝗮𝗻𝗰𝗲 𝗔𝗱𝗷𝘂𝘀𝘁𝗺𝗲𝗻𝘁
    A stylus that is perfectly centered in the record groove - when viewed from the front - and not leaning one way or the other can give us optimal stereo separation and is one of those keys for big soundstage. This angle of the stylus is called azimuth.
    You'll need a test record with a mono reference signal at a steady output level. I use Track 1 of Side 1 of The Ultimate Analogue Test LP.
    Have the Puffin set up with your favorite cartridge and your typical settings. Then adjust as follows:
    Mode:Stereo
    Magic:OFF
    Fine Balance +00 Phase:Null
    Go to the Levels VU in Average mode, paying attention to the second line, "D av -XX.X -XX.X". Go ahead and play the test signal. You can even have your system volume muted so that you don't have to hear the obnoxious test tone, as we are just monitoring the levels.
    Since we are in Null mode, we want this to be as low a negative number as possible (e.g. -50.7 is better than -48.5). In Null mode were are subtracting the two signals from each other, so if the two channels are perfectly aligned, theoretically we'd get absolutely nothing (-99.9 on the Puffin). Since there are many factors, for our adjustment we are just looking for a relative minimum, and every tenth of a dB we can drop is good.
    Adjust the stylus azimuth by rotating head shell, shimming the cart, or making the adjustment that you have on your tonearm. You'll have to research that elsewhere. For me, I have an SME type removable headshell with a little slop, so I can manually adjust a few degrees one way or the other easily. If the detected nulling average drops lower, then you are adjusting in the right direction.
    After you get that number as low as possible (i.e. stylus azimuth is now perfect), you can adjust the gain mismatch in your cartridge. Just adjust the Fine Balance for even more rejection (go one step at a time, and change directions if it gets worse).
    The only real trick is to constantly keep monitoring that you are playing the same track, so you may need to needle drop it a few times. But after you do it once or twice, the whole process is fast and easy. In my case, I usually use bubble levels, but all my carts required a few more degrees tilts inward, which indicates I need to adjust my main tonearm shaft. But now that I know the error, I can compensate easily.
    I improved all my carts 3dB to 6dB separation in this method, so this fine adjustment is highly recommended
    borglein
    Mode:Stereo
    Magic:OFF
    Så bra. Er det den test LPen som Duet selger du har benyttet?
    stianG
    Jeg har også justert azimuth på et par pickuper med puffin. Foretrekker den fremfor fozgometer.
    borglein
    Jeg har skjønt at man kan kjøpe bitumen på Biltema, men hvor fikk du tak de øvrige tingene til isolering av lundefulgen, @BeetleBug?
    BeetleBug
    Blant annet Würth men sikkert også Biltema. Jeg isolerte glassfiberfronten med en klemlist av gummi. Skruene isolerte jeg med blant annet o-ringer. Det samme med RCA pluggene. Morsomt og hørbar forskjell.
    -BB-
    borglein
    Det så veldig bra ut. Jeg må vurdere om dette er noe jeg tør å tukle med, men bitumen bør i hvert fall være greit å få til. Hva heter det rød du har rundt boltene?
    frode n
    Jeg driver å eksperimenterer litt med demping på baksiden av mine høytaler elementer. I den forbindelse ble jeg gjort oppmerksom på at bitumen tørker og på sikt mister sin evne som vibrasjons dempende materiale. ( Her snakker vi om år )
    Ble i steden anbefalt butyl. Beregnet for vibrasjon og støydemping innvendig i biler. Har vært på Thansen i dag og kjøpt en pakke til 179 kr. 82 x 46 cm. De har også 30 x 30, 2 stk til 129 kr.
    Hva som er riktig, og hva som er best vet jeg ikke, bare ment som et innspill
    ragwo
    Mud-fi freak
    El-returen
    Har brukt butyl selv, men byttet til bitumen da butylen var noe gris å jobbe med. Kan godt se for meg at bitumen tørker ut etterhvert, takk for tipset!
    borglein
    Imponerende! Noen førsteinntrykk å komme med?
    Har bare såvidt testet, men lover bra. Kanskje litt lite trøkk i bassen, men sikkert mulig å få justert det inn. Litt uvant med kun 200 ohm lasting og masse EQ muligheter. Pleide å kjøre 50 ohm og 72db gain på min Jasmine LP2.5 DU. Er i hvert fall fornøyd med mindre gain. Noe som har tips hvordan jeg burde kjøre EQ for å tilsvare hardere lasting? Bruker en Dynavector 20x2 low output.
    frode n
    Den jeg har kjøpt i dag er litt gummiaktig med lim på en side og aluminiums "folie" på andre. Denne virker ikke løs / grisete.
    ragwo
    Mud-fi freak
    El-returen
    Høres ut som om du har fått tak i noe som er litt fastere i fisken enn Biltemas variant som jeg har brukt.
    ragwo
    Mud-fi freak
    El-returen
    Hvis jeg ikke husker feil er det Air du skal bruke for å simulere annen last.
    borglein
    Hvis jeg ikke husker feil er det Air du skal bruke for å stimulere annen last.
    Hadde allerede sett i manualen, men man blir litt perpleks når det er så mange muligheter. Får prøve litt ut.
    borglein
    Dette spiller som en kule! 200 ohm, 64db gain og +1 air virker som en bra innstilling, men har ikke testet så veldig mange innstillinger foreløbig. Kan i hvert fall konstatere at dette definitivt ikke låter "digitalt". Eneste minuset er at jeg ikke kjøpte denne før jeg gjorde.
    stianG
    Puffin er virkelig bra, og ikke bare "til prisen". Jeg eier for tiden to phonotrinn. Puffin og Wavac lcr x2. Det er en sann glede å høre musikk via Wavac, men det er det sannelig gjennom puffin også!
    300B
    Sogn og Fjordane
    Må melde meg inn her ettersom jeg har kjøpt meg en Puffin med digital utgang Jeg syns dette er er røverkjøp til prisen, men det har manglet litt oppløsning og bakgrunnen har ikke vært så sort som jeg skulle ønske.
    Ser flere her ikke har noen særlig tro på å bytte strømforsyning, men jeg kjøpte meg likevel en iFi iPower X.
    Du verden for en forskjell. Her ble alle parameter betraktelig forbedret, og nå savner jeg veldig lite i forhold til andre betydelig mer kostbare RIIA’er jeg har testet tidligere. Jeg vil påstå at dette er vel anvendte 1150kr.
    ragwo
    Mud-fi freak
    El-returen
    Hvor kjøpte du strømforsyningen?
    ragwo
    Mud-fi freak
    El-returen
    Nyheter fra Lundefuglens far!
    Fuglen kommer nå med optisk utgang for dem som ønsker det. Videre kan de nyeste fuglene synge 24/96 over coax. Litt kjipt for meg som kun har 24/48 ut og skadeskutt hørsel. Tror 24/96 ville fjernet både tinnitus, overfølsomhet og upgradius nevrosa. Sistnevnte hadde hvertfall forsvunnet for et par dager/uker/måneder.
    Bjørn.H
    Har de 24/96 når du bestiller siste versjon?
    borglein
    Han svarer jo så raskt på e-post at man nesten ikke rekker å områ seg.
    borglein
    Har testet litt mer og fant ut av at det ble litt for lite vekt i bassen, og litt for lyst/skarpt med denne innstillingen. Jeg har prøvd meg på både 200 ohm og bass +1, og tilt -1, men tror +1 i bassen er best. Noen som har noen innspill til hvordan de ulike innstillingene påvirker mellombass i praksis? Jeg liker 200 ohm uten annen EQ ellers i lyden, men det blir for lite punch.
    Balle Clorin
    bestilte min Puffin med Toslink 24/96 ut idag :)
