  • Asbjørn
    Vi forklarer dem at russerne
    kom, de så og de konstaterte at det ikke var mulig å leve her! Det var de jævligste forhold de noensinne hadde opplevd så de snudde
    og dro hjem så fort de kunne!
    Den russiske erfaringen fra arktisk krigføring, slik den ble oppsummert etter WW2 var «bør unngås». Ting går i stykker, været kan drepe en hær, jernbane finnes ikke, veiene blir til gjørme og tanks drukner i myr. De få farbare veiene blir sterkt kanaliserende og de lange forsyningslinjene blir ekstremt sårbare. Logistikk er ikke en russisk paradedisiplin, akkurat.
    Du har et visst poeng der. :)
    People have used the word, because the Russian position would actually be logical for a culmination—and has been for a while. The Russians have expended a huge amount of resources for months to take almost nothing and the Ukrainians are preparing a counteroffensive. However what is clear is that this kind of logic does seem to be missing from Russian operations. Clausewitz would probably look at Russian military behaviour and despair—to a degree that even using a Clausewitzian framework to attempt to analyze what the Russians are doing might not be worthwhile. Instead of their being a logical culmination, the Russians will just keep wasting resources where the Ukrainians want them to, stopping when they run low for a few days, then starting up when the forces become available—advancing a few blocks here or there. As I said, that seems to be exactly what Ukrainian high command has wanted.
    Stalin and Hitler were maniacs, but they had competent officers to whom they listened. Putin is a military ignoramus directing completely incompetent generals.
    svart-hvitt
    RIP
    «Kostiantyn Starovytskyi, conductor of Kyiv Opera, died at the frontlines defending his country from the russian invasion. Kostiantyn went to defend Ukraine in the first days of the full-scale invasion. He left a young daughter and a wife, who will need to learn how to live without him. I can only imagine their pain from loosing a father and a husband».
    Lenke: https://www.linkedin.com/posts/roma...tor-of-kyiv-activity-7049750348650987520-GyzD
    Apropos det: Jeg forsøkte å få google maps til å foreslå en rute fra Grense Jakobselv til Alta flyplass. Svaret var at det ikke er mulig å komme frem dit derfra.
    Apples karttjeneste var litt mer informativ da jeg søkte på bilvei:
    Kollektivtransport og sykkel som transportmiddel ga variasjoner av samme resultat.
    Men hvis jeg sa «skit i bilfaan, æ går!» hadde den et forslag:
    Fire og et halvt døgns kontinuerlig marsj via Enare sjø, ja.
    Du har fortsatt et poeng. Den gamle russiske læreboken i arktisk krigføring likeså. Ikke forsøk.
    Hønndjevelen
    Vi får håpe russerne gjør som budbil sjåførene, bruker Google maps om de tenker på invasjon.
    Var det ikke derfor de hadde en 60km lang kø med sittingducks på veien til Kyev?
    Wishmaster
    Spiralis
    Etter at jeg flyttet til Finnmark har jeg lært meg et par lure triks i Ludo. Skal man på biltur er det lurt å ha med vinterkjeledress/scooterdress, varmedress til bruk inne i bilen, ulltepper og soveposer til alle i bilen! Spade!! Matpakke, type XXL, 10-20 liter Jerrykanne med bensin/diesel. Ikke fordi det er for langt mellom bensinstasjonene, det er ikke lenger noe problem etter at det ble mulig å betale med kort på stengte stasjoner. Men fordi det kan være lurt å ha drivstoff til å holde motor/varmeapparat evt diesel/bensinvarmer i drift slik at ikke bilen blir fryseboks før det er helt nødvendig. Vinterkjeledress/scooterdress og spade slik at man kan spa bilen gjennom snødriver om nødvendig. Matpakke slik at man ikke sulter hvis man ikke klarer å spa bilen fri. Man riskerer å bli stående på en fjellovergang mellom bommene hvis drittværet kommer for fort til at vegvesenet kan kjøre over fjellet for å sjekke om noen står fast. Og så det geniale, mange av disse øde "fjellovergangene", ( i hermetegn fordi det ikke er høyfjell vi snakker om, men natur og værforholdene er ganske likt det man finner på Hardangervidda ) har heller ikke mobildekning! Har mange ganger vurdert å kjøpe satelitt telefon igjen, men det er så sjelden man roter seg opp i slike situasjoner at det er vondt å rettferdiggjøre investeringen/driftkostnadene. Det er billigere å sjekke værmeldingen før man starter hjemmefra. Enkelt sagt så setter man ikke i gang på biltur om vinteren her oppe i dress og lakksko!
    Når det gjelder Asbjørns eksempel så er veien fra Grense Jakobselv til "sivilasjonen" (Vintervollen) stengt om vinteren. Har man ikke snøscooter så drar man ikke den veien. Nå i påska er det gudstjeneste i Oscar II's kapell i grensen. Da må man bestille transport med garnisonen som stiller med Hegglunds bandvogn. Uten å ha vært der i vinter kan jeg tenke med at det ligger noe mellom 1,5 til 3 meter snø på veien der. På plena foran huset mitt er det nå rundt 1,75 dyp snø. Men tilbake til ruteplanleggeren. Før de setter opp snøscooter som alternativ kjøredoning vil den ikke fungere om vinteren. Dessuten er det på grunn av rasfare og fastkjørte vogntog vanskelig å si hvor lang tid man må beregne etter landeveien mellom Sør Varanger og Alta. Nå er det ikke lenger fastboende i grense Jakobselv om vinteren, så det er ingen som har akutt behov for å kjøre på den veien. Hvis en hyttegjest blir syk blir det snøscooter eller helikopter. Og rent praktisk vil man nok bruke Widerøe ( ja dyrt som pokker, men det er "trikken vår! ) for å forflytte seg fra Kirkenes til Alta. Må man bruke bil så kjører man gjennom Finland, bedre veier og knapt rasfare i det store og hele. Den siste biten inn til Alta fra Finskegrensa kan selvsagt by på interessante opplevelser, men "normalt" går det greit. Det kan være forjævlig uvær på kysten av Finnmark, mens Sør Varanger og Finland går glipp av det aller meste.
    Nå er dette en tråd om Russlands invasjon i Ukraina, så det mest relevante er vel å anta at russiske kolonner blir stående værfast/rasfast mellom snøras. Og da er det bare å håpe at Yankeene kommer med sine A-10 og sier Brrrrrrrrrrrrrrrrrrrrt
    otare
    Spørsmål: "Hvordan kan vi vite når Putin lyver?"
    Svar: "Når leppene hans beveger seg!"
    Spiralis
    Etter den der så kjenner jeg at det er helt greit at jeg bor et stykke sør for Sinsenkrysset.
    Joda forstår det, men det er nok mest et spørsmål om hva man er vant med. Bor man i et distrikt der det kun er hvert "jubelår" at saltet ikke tar knekken på snøen vil det selvsagt bli prolemer når det brått ligger 5 cm med hvit sørpe på veien. Etter drøyt 40 år i Finnmark er det slikt som man har vent seg til. Sånn er det bare. På andre måter er vi nord ganske priviligerte. På tur mellom Tromsø og Kirkenes med bil har jeg sett et utall av hare, rev, ørn, bjørn, elg og reinsdyr. Ikke alle som har det! Den klassiske er den tyske bobilen som stopper på den gule midtlinja, begge dørene går opp og et eldre tysk ektepar hopper ut av bilen og selv om man ikke kan høre det så vet jeg hva som blir sagt: " Reintier!! Helga hast du den kamera?" Joda forstår dem men blir like forbannet hver gang! ;) For oss som bor her er jo reinsdyr og elg så vanlig at vi ser på dem som en plage og trafikkfare. Som også gjelder for tyskere i bobil. Men man forsøker jo å slappe av og la dem leve i fred, både dyrene og tyskerne!:giggle:
    Edit: Typo
    svart-hvitt
    Det var en som sa noe om at én manns himmel er en annen manns helvete😅
    Tror ikke godt vante russere var interessert i Finnmark når Krim og Vyborg lokket.
    skranglefant
    Bartistan
    ^^ Bjørn?? Du vinner. Jeg tror de skarpeste tennene jeg har kjørt over/forbi tilhørte en grevling, men det var på Lillehammer og ikke på eks-hjemmebane :rolleyes:
    Spiralis
    Bortsett fra den russiske bjørnen er det dyret faktisk ganske fredelig og trekker seg unna når den merker at det er folk i området.
    Frykter den ikke i det hele tatt. Du skal ha maksimalt med uflaks om du skremmer en bjørn slik at den blir aggresiv. Den russiske er dog noe helt annet. Den må som mine finske venner sa det: "Møtas med varma pipor!" Eller som en annen norsk kompis sa det: "Kommer de får vi bare møte dem som best vi kan, og slukkes lyset er det bare å håpe at de som finner meg ikke finner masse ubrukt ammo også!"
    Vi vet hva som skjer med de sivile hvis man gir seg i kamp mot de der! Det er derfor ikke noe alternativ!
    skranglefant
    Bartistan
    Sist jeg så en bjørn var i Bern (!) i 2016 og...
    ...de bedrev seriØs slow slo-mo. Ikke akkurat kaninfart :D
    Edit: Uvisst om disse var russiske
    JMM
    Slava Ukraini!
    Fredrikstad
    Nå nå, jeg har ikke alltid bodd der jeg bor i dag og jeg er gammel nok til huske brøytekanter som var tre ganger så høye som meg selv, samt en selvbygd igloo i bakhagen som sto i to og en halv måned før den ikke lenger var trygg å sove i. Jeg skulle veldig gjerne hatt slike vintre igjen, men altså bare hvis de opptrådte her.
    PowerMetal
    The documents mention, for instance, the expenditure rate of HIMARS — American-supplied high mobility artillery rocket systems, which can launch attacks against targets like ammunition dumps, infrastructure and concentrations of troops, from a distance. The Pentagon has not said publicly how fast Ukrainian troops are using the HIMARS munitions; the documents do.
    Another document includes columns that list Ukrainian troop units, equipment and training, with schedules for January through April. The document contains a summary of 12 combat brigades that are being assembled, with nine of them apparently being trained and supplied by the United States and other NATO allies. Of those nine brigades, the documents said that six would be ready by March 31 and the rest by April 30. A Ukrainian brigade has about 4,000 to 5,000 soldiers, analysts said.
    ^ De «lekkede» dokumentene er grundig modifisert av russisk etterretning, wikileaks-style, ukrainske tapstall blåst opp og muskovittenes redusert med en faktor på ti eller så. Likevel litt interessant at seks tungt bevæpnede brigader sies å være klare nå og tre til om noen uker. Vet ikke om det stemmer, har sett spekulasjoner andre steder om femten mekaniserte brigader i løpet av våren. Det er en seriøs knyttneve.
    Uansett, litt langlesning på en langfredag:
    As for the need to avoid inflammatory language to preserve the chances of a negotiated peace, in 1994, Ukraine gave Russia the nuclear weapons left on its territory by the collapse of the Soviet Union. In return, Russia, the US and UK gave Ukraine security assurances. They were, of course, worthless. As someone who marched with the Campaign for Nuclear Disarmament in the 1980s, it pains me to admit that tens of thousands of Ukrainians would be alive today if the new state had learned to love the bomb.
    After the Russian invasion of Crimea and eastern Ukraine in 2014, the international community agreed in the Minsk accords to uphold a ceasefire and reconcile differences . Russia invaded again in February 2022.
    No negotiated peace with Russia is worth the paper it is written on because of the fascistic nature of Russian nationalism.
    U
    Utgattmedlem 762
    Har nok noe med antall biler og mennesker i forhold til steder der ingen kan tru at nokon kunne bu :ROFLMAO:
    Statistikk viser at hele to av tre biler i Finnmark var innblandet i trafikkuhell forrige vinter, altså en betydelig høyere andel enn «sørafor». Avisene skrev kanskje ikke så mye om det, men begge bilene måtte faktisk på verksted etterpå.
    Poirot
    He, he.
    Billige sigaretter i Sverige?
    60 mil tur-retur Oslo-Gøteborg med buss. Hvor mye koster bussbilletten? :unsure:
    svart-hvitt
    Et poeng som er så viktig at man må skrive det ned. NATO er bare til bry for en nasjon med spinnville tanker om seg og verden.
    svart-hvitt
    Lønnsom tur. En kartong sigg i sverige er drøye 600,- - i Norge 1600,-
    Hadde han gått av i Strömstad, ville billetten vært billigere og han hadde spart en del tid.
    Ærlig talt. Noen som tror at en russer drar til Göteborg for sigaretter?
    svart-hvitt
    Av Francis Fukuyama og Nino Evgenidze
    «Georgian civil society remains ferociously dedicated to a Euro-Atlantic future, and with adequate support from the West, it could help resist further encroachment by Moscow. After all, Georgians were the original victims of Russia’s post-Sovietimperialism—canaries in the coal mine whose warnings back in 2008 went unheeded. This time, their warnings must be heard, unless the West is prepared to let Russia fully capture this deeply threatened democracy».
    Maka til feiloverskrift av noen, som ikke har peiling 😁 😁
    Ernst Stavro Blofeldt har så ingenting å gjøre med Dr. NO 🤣🤣🤣🤣
    Derimot tjenestegjorde min far som menig kystartillerist på Sørvikneset. Det var noen historier, men kanskje ikke så mange som handlet om høy beredskap og forsvarsevne.
    Den ene gangen det gjaldt i 1940 fikk ingen på fortet summet seg til å åpne ild i tide, bare ett enkelt kanonskudd etter at tyske krigsskip allerede hadde passert. Likevel et visst fremskritt fra 1914, da festningen også var mobilisert, men en tysk hjelpekrysser/minelegger kunne passere uten engang å bli oppdaget før den ankret opp i Trondheim.
    Det var riktignok lenge før min fars tid, men jeg tror ikke norsk forsvarsevne ble så veldig svekket av å legge ned det batteriet.
    HasseBasse
    Hjortshøj, Danmark.
    Dr.No er den med Ursula Undress i Karibien.
    Litt sent å drømme om Ursula nå, men vi har fortsatt Karibien.
    Åhhhh ja..... Ursula 🤣 🤣
    Men Dr. NO var asiat....... ligger ikke helt til navnet "Blofeldt", eller???
    Er det bare kvaliteten på dagens skribenter, som vi må nøyes med?? :oops:
    HasseBasse
    Hjortshøj, Danmark.
    Tok ikke lenge, før noen med vett fikk korrigert 🤣🤣
    Rettelse
    I en tidligere versjon av denne saken sto det at Ernst Stavro Blofeld er bedre kjent som Dr. No. Dette er ikke riktig. Dr. No var kun med i den første filmen i James Bond-serien. Superskurken Blofeld har hatt ulike roller i totalt ni av de 25 filmene i serien, senest i No Time To Die fra 2021. Dette ble rettet 07. april klokken 18.53.
