Prøv selv, da vel, din paranormale nisse!
Ikke la all kunnskap og fornuft stå i veien for deg hele tiden
Du har jo et poeng, men kanskje det er
mangel på forståelse som nettopp står i veien for meg?
Jeg har faktisk prøvd tilsvarende produkter fra Nordost, bla Pulsar Points. Nå forstår jeg at dette er i en helt annen liga, men likevel, de fikk svært så positiv omtale den gang de ble lansert. I mitt søken etter godlyd, hev jeg meg selvfølgelig over så mange sett jeg følte jeg hadde råd til.
SoundStage! Max dB - Let's Get Right to the Point - Nordost Pulsar Points (07/1999)
I really like the way Pulsar Points sound in my system. They impart a sense of dynamics and drive to the system that other feet don’t. They also seem effective over a wider frequency range than most feet. Black Diamond Racing cones are the only others I’ve tried that seem to affect as broad a frequency range, though they sound quite a bit different -- less dynamic and more delicate than Pulsar Points. Brass cones sound more lightweight and lean towards an emphasis of the mids, upper mids and lower treble. Pulsar Points bring out detail with out any sense of emphasis anywhere. Other cones sound lumpy in comparison. There will be multiple bands where improvements are heard interspersed with other bands that are not changed or that may sound even a little worse. This effect is not obvious until you hear Pulsar Points in comparison to other feet. The other feet I used as references seemed just fine on their own -- until I heard the Pulsar Points. I’ve ended up replacing the Twinkle-Toes on two LaserBase equipment isolation/support stands with Pulsar Points to great effect. The Pulsar Points sound a little better and cost half as much as the manufacturer’s option. Pulsar Points are also on duty under the preamp’s outboard power supply, where they decimated all challengers most convincingly.
Jeg prøvde under flere komponenter, men effekten Nordost og pressen lovet uteble. Jeg innser nå at jeg kanskje ikke brukte dem riktig og at jeg kanskje har misforstått noe av fysikken jeg lærte på skolen.
Kanskje noen kan forklare meg hva disse gjør rent fysisk, så kan jeg kanskje gi de en sjanse til? Jeg har forstått at de skal isolere komponenter fra lavnivå resonanser, kanskje mine resonanser er på et for høyt nivå? Jeg har også forstått at de må være svært bredbåndede da de takler utstyr opp i mot 100kg. Merker dere endringer om dere tilfører vekt, eller er det slik at de "føler" av vekten slik at de isolerer uansett vekt?
Takk på forhånd for innspill som kan styre meg på rett vei!
