Det er en beskrivelse jeg kjenner igjen når jeg satte mine egne høyttalere på disse plattformene.The effect of putting a speaker on the Seismic Podiums is quite dramatic. I did the demonstration to the guys from DALI recently when they brought round a pair of Epicon 8 speakers for a forthcoming review. They couldn’t quite believe the improvement in coherence and timing it wrought, and the extent to which the sound is able to escape the boxes. Then there’s the bass, which is suddenly incredibly articulate, three dimensional, and powerful. This is true of every speaker that I have tried on these bases, and the irony is that the sound is faster and more fine detailed than it is with spikes. There is none of the edginess and emphasis on leading edges that spikes produce, yet there is greater immediacy. In all honesty, I’d say you don’t know how good your speakers are until you isolate them from the floor.
De er ganske så dyre. Starter på drøyt 12.000 kroner for de minste, size 1. Mine er Size 2, og koster 15.000 kroner for et par. Dog fikk jeg tak i mine brukt til 5500 kroner.Tøffe, hva er prisen på de?
Litt morsomt at Jason Kennedy nevner samme høyttalerne som de du har i testen av isolasjonsplattformene.Takker
RoyI did the demonstration to the guys from DALI recently when they brought round a pair of Epicon 8 speakers for a forthcoming review. They couldn’t quite believe the improvement in coherence and timing it wrought, and the extent to which the sound is able to escape the boxes. Then there’s the bass, which is suddenly incredibly articulate, three dimensional, and powerful.
Jeg ville nok heller gått for en som er litt for stor, enn en som er litt for liten. Vekttilpasningen kan du jo gjøre uavhengig av størrelse på selve plata.Spennende plattformer, ser bra ut også Hadde veldig god effekt med Base Technology under Magnepan 3.6 for noen år siden (spesialtilpasset). Hadde vært spennende å testet disse, men skulle hatt en mellomting mellom Size 2 og 3. Kunne kanskje klart meg med 2 med et nødskrik.
Roy
Gjør det. Vet han hadde noen brukte til salgs for en stund siden, men det var en av de større modellene. Har han de ennå, så kan vel muligens de lånes ut slik at du kan sjekke effekten før du bestemmer deg for å kjøpe eller ikke.Jeg ville nok heller gått for en som er litt for stor, enn en som er litt for liten. Vekttilpasningen kan du jo gjøre uavhengig av størrelse på selve plata.Spennende plattformer, ser bra ut også Hadde veldig god effekt med Base Technology under Magnepan 3.6 for noen år siden (spesialtilpasset). Hadde vært spennende å testet disse, men skulle hatt en mellomting mellom Size 2 og 3. Kunne kanskje klart meg med 2 med et nødskrik.
Roy
Joda, er enig i det, var kun dette med prisen da
Kanskje jeg skal ta kontakt med de for å høre om det kan testes, hvis jeg tør.... kan bli dyrt om det virker
Ja så det Vært morro om det kom etpar ord om de i stereo+, setter pris på den gode jobben du gjør der.Litt morsomt at Jason Kennedy nevner samme høyttalerne som de du har i testen av isolasjonsplattformene.Takker
Takk for det. Alltid hyggelig med gode tilbakemeldinger.Ja så det Vært morro om det kom etpar ord om de i stereo+, setter pris på den gode jobben du gjør der.Litt morsomt at Jason Kennedy nevner samme høyttalerne som de du har i testen av isolasjonsplattformene.Takker
Var vel disse du savnet under mine epicon når du var innom.Den siste oppgraderingen i anlegget er bare et par dager gammel, men forbedringen er åpenbar. Er det noen andre her som har erfaring med Townshend Seismic Podium?
Vis vedlegget 466535
Du kan lese mer om plattformene HER
Jason Kennedy i Hifi+ skrev følgende:
Roy
Skal ikke kimse av far-til-far-julegaver, he-heVar vel disse du savnet under mine epicon når du var innom.Den siste oppgraderingen i anlegget er bare et par dager gammel, men forbedringen er åpenbar. Er det noen andre her som har erfaring med Townshend Seismic Podium?
Roy
Takker for tips, skriver de på ønskelisten til jul, fra far til far
Den lydmessige beskrivelsen kjenner jeg meg også igjen i. Alt åpner seg mer med Townshend-basene.Jeg har sånne under mine Magico V3 og ja, de virker! Ikke bare i bassen, men gir også et klarere lydbilde og ikke minst isolerer de høyttalerne fra gulvet. Naboene vil takke deg!
Sorbotan-føtter fungerer ypperlig de også. Som BigSwifty, så er fordelen til Townshend-podiumene fleksibiliteten som Sorbotan-føttene ikke har. Hvert av de fire hjørnene kan justeres slik at høyttalerne står i vater uansett hva slags vektfordelig høyttalerne har. Samtidig bygger plattformen kun to cm over gulvet, noe som er lavere enn f.eks. Soundcare som jeg brukte tidligere. Høyttalerne mine har diskanten ganske så høyt plassert på frontbaffelen, så å senke den en centimeter eller tre, oppleves bare som positivt.Jeg rekker opp hånda med ett spm:
Hva gjør disse plattformene som ikke noen sorbothane føtter klarer å gjøre til en langt rimeligere pris? App`n som benyttes i videoen over her koster 55 kroner og jeg morret meg litt med den og disse i går kveld:
Resultatene mine var omtrent dem samme som i dem i videoen og dem mer eller mindre bekrefter budskapet til flere her inne som hevder at spikes ikke alltid er riktig løsning.
BB
PMC har kjørt sine 88 kilo tunge monitor-høyttalere på disse podiumene, så tror ikke du slipper helt unna selv med tunge høyttalere.Spennande plattformer. Eg har prøvd litt av kvart, og funne Soundcare til å vere det mest nøytralitetsskapande eg har hatt under høgtalarane. Men av og til har det vore meir tilfredsstillande med andre ting. Spesielt har det vore mange tilfelle av å bruke sorbotanklossar mellom høgtalarar og fliselagt golv. Men det i kraft av feitare bass , ikkje meir nøytralitet.
Men under dei 85 kg tunge MBL 101E2 har val av underlag svært liten effekt. Kanskje på grunn av høg masse? Då eg hadde InnerSound var skilnaden svært stor.
Skulle vore moro å prøvd desse greiene.
Kult. Hva ligger de på i pris?Som et tips så har CEC sine plattformer også samme funksjon. Fungerer opp til 90 kg. Bruker de under mine.
Ja, jeg har brukt AVC-blokkene under høyttalerne, og jeg opplever de som bedre enn f.eks. Soundcare, men forskjellen er langt større til Podiumene. Lyden åpner seg langt mer og detaljnivået øker i hele frekvensområdet.Har du testet Audiophile Vibration Control klossene vs Townshend Seismic Podiums
under høytalerene? stor lydforskjell. Har myst litt på Townshend podiums men prisen har stanset meg noe
Soul Mining er også bra, der den singelen er hentet fra. Har Soul Mining på cd (om jeg husker riktig)
