Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • Hardingfele
    Glenn Gould pleide øve pianospill med støvsugeren på. Billigere enn å betale 60 for VDs seneste påfunn. Jeg har markert det som er relevant for alt tweak-tøys.
    "Somehow, I cannot help thinking of something that happened to me when I was thirteen or fourteen... I happened to be practising at the piano one day – I clearly recall, not that it matters, that it was a fugue by Mozart, K. 394, for those of you who play it too – and suddenly a vacuum cleaner started up just beside the instrument. Well, the result was that in the louder passages, this luminously diatonic music in which Mozart deliberately imitates the technique of Sebastian Bach became surrounded with a halo of vibrato, rather the effect that you might get if you sang in the bathtub with both ears full of water and shook your head from side to side all at once. And in the softer passages I couldn't hear any sound that I was making at all. I could feel, of course – I could sense the tactile relation with the keyboard, which is replete with its own kind of acoustical associations, and I could imagine what I was doing, but I couldn't actually hear it. But the strange thing was that all of it suddenly sounded better than it had without the vacuum cleaner, and those parts which I couldn't actually hear sounded best of all. Well, for years thereafter, and still today, if I am in a great hurry to acquire an imprint of some new score on my mind, I simulate the effect of the vacuum cleaner by placing some totally contrary noises as close to the instrument as I can. It doesn't matter what noise, really – TV Westerns, Beatles records; anything loud will suffice – because what I managed to learn through the accidental coming together of Mozart and the vacuum cleaner was that the inner ear of the imagination is very much more powerful a stimulant than is any amount of outward observation".
    funbunny
    Ved Mjøsa
    Det er litt retro-tech over det. De fleste av oss har vel allerede gått over til harddiskbasert avspilling og streaming, så "perfekt avspilling av en CD" begynner å ligne litt på "perfekt fyring under en dampkjel" i mine øyne. Et mekanisk CD-drev som skal spille av musikkfiler i sanntid er en dyr og komplisert måte å gjøre det på når det finnes løsninger som er bedre, enklere og billigere på en gang.
    Det er mange transportere som buffrer før avspilling (bla. min) så da er ikke forskjellen fra strømming like stor.
    Uten å ha gjort pinlig nøyaktige sammenligninger så holder jeg en knapp på CD avspilling vs. 'harddisk' avspilling (SSD) for kilder med samme oppløsning.
    Har dog ikke forsikret meg om at opprinnelsen er samme Master og volum-matchet med SPL-meter.
    Dette skal jeg dog gjøre, så får vi se om min uformelle sammenligning holder vann.
    Mulig jeg har nevnt dette før, men harddisk avspilling ( fra Mac ) er ikke en sak. Har opplevd store variasjoner i lydkvaliteten ( i disfavør USB disk ) mellom USB og Firewire basert harddisk avspilling. Mange ting som kan gå galt mhp. signaltiming...
    Funbunny
    Z
    Zomby_Woof
    Men dette er altså ståa om dagen. Dette er hva konstruktørene av 'high end audio' holder på med. Tester forskjellige lengder av nettkabler for å komme opp med den optimale....
    Fallet fra Edison og Berliner er avgrunnsdypt.
    Zeitgeist
    Melhus
    Klistre den her på forsterkeren og du får fantastisk lyd.
    AQVOX Spectrum Harmonizer - Crystal Glass Cylinder
    Optically appealing tuning elements with AQVOX formatting and hologram seal
    Tuning elements for devices, cables, windowpanes, mirrors, radiators, multiple socket outlets, fuse boxes.
    The formatted material brings about that electromagnetic frequencies are harmonized and electromagnetic pollution (electro smog) is minimized.
    What is the AQVOX formatting:
    Using a special process, which has incorporated our 30 years of experience in the optimization of audiophile audio components, the material receives a special formatting information. The formatted material brings about that electromagnetic frequencies are harmonized and electromagnetic pollution (electro smog) is minimized.
    The sound gets more depth and three-dimensionality. The timing gains precision and the dynamics are increased. Altogether the tuning with AQVOX formatted accessories brings considerably more naturalness and emotionality. The music sounds less canned and gets more live character. Normally, the tonality is not being affected. The sound does not become brighter or darker.
    Application:
    To put on top or underneath, or to adhere (double adhesive foil included).
    For devices, cables, windowpanes, mirrors, radiators, multiple socket outlets, fuse boxes.
    Så rart, men den låter tydeligvis eksakt som de fleste placeboer jeg har testet.
    Har noen lagt merke til at bilen går bedre etter at den har blitt vasket, forresten?
    E.H.
    I teorien skal man jo kunne oppnå både høyere toppfart og kraftigere akselerasjon med nyvasket bil, litt avhengig av hvor skitten den var før da.
    Men ja, alle mine biler har blitt mye raskere av vask, spesielt om sommeren merkelig nok, da er den jo ikke så skitten før vask.
    Ikke akkurat ukjent for mange at Furutec er et merke man absolutt bør holde seg borte fra dersom man ikke ønsker å øse penger inn til alternativ bransjen.
    Nå kommer NCF Booster
    The NCF Booster is almost here! | FURUTECH
    A new kind of audio accessory will be relased by Furutech at the end of October.
    The NCF Booster is a multifunctional performance-enhancing connector & cable holder. The much antcipated NCF Booster has been receiving rave reviews in Japanese publications and such was demand that initial production runs sold out to industry insiders in Japan before the NCF Booster even reached audio store shelves.
    Furutech has since increased production to allow for international release in late October.
    What is the NCF Booster?
    It is a multi-material, hybrid constructed performance-enhancing connector & cable holder for superior connetcor and cable damping.
    Not only does the Furutech NCF Booster Connector and Cable Holder lift audio cables off the floor minimizing their points of contact with the floor, reducing electromagnetic interference, it also excels at providing NCF damping support for connectors and cables at points of connection. The NCF Booster Connector and Cable Holder allows for the optimum alignment between connectors and sockets and eliminates static – boosting performance by allowing a more pure and clear signal.
    NCF: Nano Crystal² Formula
    Developed by Furutech, NCF features a special crystalline material that has two ‘active’ properties. First, it generates negative ions that eliminate static. Second, it converts thermal energy into far infrared. Furutech combines this remarkable material with nano-sized ceramic particles and carbon powder for their additional piezoelectric damping properties. The resulting Nano Crystal² Formula, exclusive to Furutech, is the ultimate electrical and mechanical damping material.
    QUE?
    Her er det bare å klampe fast strømpluggen din som selvsagt også må være Nano Crystal belagt og helst noe Quantum greier.
    Før dette er gjennomført er følgende egenskaper ikke oppfulgt i stor nok grad.
    Increased sound to noise ratio, strengthened contrast and definition, response speed improved, transparency increased and distortion reduced… improved space, depth and imaging. So surprised by how much of an effect this product brings.
    Jeez.
    Fikk vel bekreftet at det er noen som går på tweaks. Jeg tror faktisk ikke det finnes tweaks som er så "over the top" at ingen går på dem. Det er absolutt ingen grenser.
    Det er fristende å plukke fram min post #2 og Crusty sin #3 i denne tråden, anno 2012, http://www.hifisentralen.no/forumet/forskjeller-og-testmetodikk/65224-finnes-det-noen-tweaks-som-er-sa-over-top-ingen-ga-r-pa-de.html#post1430754.
    Det er alltid noen som insisterer å la «ørene» bestemme. Som i mange tilfeller kan være det samme som selgerens entusiasme, rosende omtale i positive feedback, 6 moons el. og/eller selvtilfredsheten med «selv» ha tweaket husalteret (jeg har gjort noe så da må det låte annerledes = bedre) mm. «Det aller beste» kan av og til være godt nok, bare synd at «det aller beste» har mistet bakkekontakten.
    Behold. Ca 60000 så får du ny audio grade nettverks switch. Pluggene brukes i outer space må vite.
    https://jcat.eu/featured/m12-switch-gold/
    En bruker bare ca 10 sekund på å merke forbedringen.
    Nok et merke man bør holde seg unna.
    Så venter man på en audio grade psu til denne. Følger kun med medical grade.
    ^ Fantastisk, retningsbestmte SATA-kabler !!! Må en vende kabelen hvergang en veksler melleom å lagere vs å skrive data ? De skriver at den fungerer best mot disken med operativsystemet, er en da stuck dersom musikken er lagret på en annen disk ?
    Etter å ha lest enda noen blomstrende eventyrfortellinger av Aqvox/Furutech/Nordost-typen tror jeg at vi får ta en ønskereprise på denne:
    On the reception and detection of pseudo-profound bullshit
    Thus, bullshit, in
    contrast to mere nonsense, is something that implies but
    does not contain adequate meaning or truth. This sort of
    phenomenon is similar to what Buekens and Boudry (2015)
    referred to as obscurantism (p. 1): “[when] the speaker...
    [sets] up a game of verbal smoke and mirrors to suggest
    depth and insight where none exists.” Our focus, however, is
    somewhat different from what is found in the philosophy of
    bullshit and related phenomena (e.g., Black, 1983; Buekens
    & Boudry, 2015; Frankfurt; 2005). Whereas philosophers
    have been primarily concerned with the goals and intentions
    of the bullshitter, we are interested in the factors that predispose
    one to become or to resist becoming a bullshittee.
    Moreover, this sort of bullshit – which we refer to here as
    pseudo-profound bullshit – may be one of many different
    types. We focus on pseudo-profound bullshit because it represents
    a rather extreme point on what could be considered
    a spectrum of bullshit.
    What might cause someone to erroneously rate pseudoprofound
    bullshit as profound? In our view, there are two
    candidate mechanisms that might explain a general “receptivity”
    to bullshit. The first mechanism relates to the possibility
    that some people may have a stronger bias toward
    accepting things as true or meaningful from the outset.
    Put differently,
    some individuals may have an excessively “open” mind that
    biases them to make inflated judgments of profundity, regardless
    of the content.
    The second mechanism relates to a potential inability to
    detect bullshit, which may cause one to confuse vagueness
    for profundity. In the words of Sperber (2010): “All too
    often, what readers do is judge profound what they have
    failed to grasp” (p. 583). Here, the bullshittee is simply unaware
    that the relevant stimulus requires special consideration
    The present study represents an initial investigation of the
    individual differences in receptivity to pseudo-profound
    bullshit. We gave people syntactically coherent sentences
    that consisted of random vague buzzwords and, across four
    studies, these statements were judged to be at least somewhat
    profound. This tendency was also evident when we
    presented participants with similar real-world examples of
    pseudo-profound bullshit. Most importantly, we have provided
    evidence that individuals vary in conceptually interpretable
    ways in their propensity to ascribe profundity to
    bullshit statements; a tendency we refer to as “bullshit receptivity”.
    Those more receptive to bullshit are less reflective,
    lower in cognitive ability (i.e., verbal and fluid intelligence,
    numeracy), are more prone to ontological confusions
    and conspiratorial ideation, are more likely to hold religious
    and paranormal beliefs, and are more likely to endorse
    complementary and alternative medicine.
    De som føler seg truffet må gjerne gjøre det.
    Reaksjoner: KJ
    Kule-Trygve
    Skulle gjerne postet noe bullshit her om sånn derre.... Equalizer- poesi :rolleyes:, men av verdens 7 000 000 000 mennesker, så er det visst bare en jeg vet om som skriver slike ting, og jeg kan jo ikke quote ham hele tiden heller...så er det noen som har noen gode linker??
    E. Largo
    Disco Volante
    Takk og lov. Kule-Trygve var ikke død ;)
    Reaksjoner: TT.
    TT.
    The smooth jazz guy! 😉🇳🇴
    Nedre Tonsåsen
    Fått for mye Møllers tran i kveld?:rolleyes:
    WayAhead
    Sky No Limit....
    Ionsert bomullstråd for å lage en total holografisk 3D lydopplevelse... 50 kilodollar pr bump.. dvs per 10 cm.....
    Tverrsnitt av Ultra Hi Res Ionisert Bomullskabel....
    flyer
    Det var en del oksemøkk!
    Kule-Trygve
    Nei det er en grafisk fremstilling av kapasiteten til en musehjerne ..... :)
    Med alle de synapsene så klarer den vel å høre forskjell på litt av hvert...?
    Fant forresten en god beskrivelse myntet på enkelte bidragsytere her..
    These are people with minimal experience, minimal qualifications, minimal equipment, minimal skills at listening, and tragic inability to understand science.
    So what is the problem? The problem is that they then go on the forums and loudly bash real audiophiles, shouting that in their ‘expert opinion’, cables have no affect on any stereo and it is all just hokum
    https://audiofederation.com/blog/2014/08/19/high-end-audio-cables-myth-trolls
    TT.
    Nedre Tonsåsen
    Blir tullete å argumentere på fremmedlandsk, da det for det første ikke er ens egne meninger og at vi fortsatt snakker norsk i Norge!
    WayAhead
    Sky No Limit....
    Mus hører selvsagt jævlig godt....trivelige AV tasser om de holder seg til stereoen utenomhus :)
    SRM
    Oppland
    Du må vel være en av de største trollene på hfs?:rolleyes: Du får drive på hvis du får glede av det.;)
    Kule-Trygve
    Er ikke dette en solid "trolletråd" da?
    Jo, trollene bruker masse tid på å tråle internett for å finne de mest outrerte, obskure, dårlig skjulte bløffene/ spøkene innen audio, for å "rettferdiggjøre" at de ikke helt greier å høre det de burde hørt når det gjelder all den "vanlige" hifien. Minner litt om en besettelse det hele.
    ufo
    feil ifølge Christian Koenigsegg :rolleyes:
    https://youtu.be/71wvtEZ-jcI?t=1672
    QUE?
    Jeez.
    Unødige tweaks siden framfor noen 6moons har testet
    Det er disse som har testet. Dop er lovlig i Nederland.
    Selvsagt er det mye fra Furutech de gir tommel opp.
    6moons: audioreviews Furutech NCF Booster
    baluba
    Kopervik og Bergen
    Hvem som er og ikke er troll er en uverdig diskusjon. Det at noen tar hifi så på alvor at de er villige til å skaffe seg uvenner på grunn av det er helt utrolig. HELT UTROLIG!!! Skulle faen meg tro det var superprodusenter som skal forsvare sitt livsverk for å unngå konkurs, men så er de bare noen amatører som sitter og flikker på et stereoanlegg. ;)
    Espen R
    Har Bybee's internal Quantum Signal Enhancer (iQSE) blitt diskutert?
    Vis vedlegget 471533
    "Bybee Technologies has developed a product that is energized by a surrounding energy field. Once energized, our product resonates at the same frequency as the C13 atom. (Versus the more common carbon 12 atom - emphasis added) Consequently, this creates a magnetic field of force effect. In this magnetic field, the polarity of all electrons and protons are altered, affecting their oscillation by making them more aligned with each other. This reaction creates an affect that makes the transfer or sharing of electrons between atoms more streamline and efficient; and air molecules less resistant."
    Testet i Positive Feedback:
    https://positive-feedback.com/reviews/hardware-reviews/bybeetech-quantum-signal-enhancer/
    Fra testen i PF:
    It is unfair, I think to call the iQSE a tweak because it so profoundly impacts performance to such an exceptional extent.
    Må sitere mitt eget innlegg, for nå har jeg kjøpt og skal teste ut magien! ;)
    I tillegg har jeg kjøpt andre svært tvilsomme ting fra USA. For et par dager siden byttet jeg ut signalrørene i min pre-amp (3stk 12ax7/12au7) med Cryo-behandlede rør. Fra før hadde jeg Psvane "black pearl" fra Kina som ikke var billige, nå dypfryste rør av russisk herkomst!
    Begge produktene har det til felles at måleutstyret ikke avdekker noe som helst, fra eller til :D
    Dette er gøy!
    MusicBear
    QUE?
    Jeez.
    Som en innledning til det jeg nå skal si; JEG ER EN SÅNN FYR SOM IKKE ER REDD FOR Å DRITE MEG UT.
    For det første; har lest masse av disse to entusiastiske anmelderne opp gjennom årene - kan absolutt ikke si de virker useriøse – tvert imot!
    For det andre; jeg har 15 år bak meg bak et trailer ratt, hvor jeg ikke kunne bruke air condition. Fikk hueverk så jeg holdt på å klikke etter kun få minutter. Ikke, fordi luften var nedkjølt, men fordi det i denne prosessen endrer seg med positive og negative ioner (eller hva det nå heter) i lufta, og det tok lang tid før noen fant ut av årsaken. Tro bare ikke jeg satt 15 somre og svettet for moro skyld - kunne bare ikke bruke bilenes air condition.
    For det tredje, Paul (PM Audio) mener jeg å ha hørt solgt dette Furutech greiene til bl.a. til flere musikere, som har kjøpt et med ørene som "valg-faktor."
    Paul - for dere som kjenner han - noen som vil tro han står og lyver noen opp i ansiktet?
    Så på nettsiden til Paul og fant denne:
    https://butikk.pmaudio.no/produkt/spesialprodukter/furutech-ncf-booster#product-tabs4
