Parks Audio venner
  • BeetleBug
    I've owned the Puffin now for nearly four months. I mostly listen to classic rock and jazz with some electronica thrown in. My setup is a Pioneer PLX-1000 with Ortofon Blue and Nagaoka MP-110, with the Puffin running into a Benchmark DAC2 HGC using Blue Jeans cables, with a pair of Adam Audio A7Xes as monitors and a Hsu Research VTF-3 running off the Benchmark DAC and all filtered by pure sine wave APC UPSes. Not a super high-end setup, but a competent studio monitoring setup.
    I was a little apprehensive about adding more digital into my path as I've got plenty of digital amplification going on, but having A/B'd the Puffin to my Schiit Mani, as well as an older VPI phono stage given to me by my father. Now, all audio is subjective, of course, though I've been listening to hifi audio now for the better part of my life. I needn't have worried. Not even a little.
    Care to save some time? Buy it.
    The Puffin is competent. There is no area that I feel is is lacking in, in its present form. Would a digital out be nice? Sure. Processing for weird record formats? Sure. But at its core, the Puffin is engineered, and in my opinion, Shannon made it for himself. You can tell by how it's just polished enough, and has a lot of parameters to tweak out of the box, but it doesn't need any of that. Shannon built this so he can spend more time upgrading and enhancing the experience rather than continually refactoring and rearchitecting the hardware. With time, I feel the Puffin will only grow in features and have, as my father used to say, more "toy quality."
    How's it sound? Well, out of the box, I gave it a little more gain than the base Shannon recommended. Other than that, clear, articulate, great imaging, deep, fast, musical, accurate, and yes, analogue-sounding. Without any modifications. With the tweaks, I can tone down some vinyl that was recorded a bit bright or make records sound just a hair better (to my tastes). The Puffin doesn't color the sound at all - Your choice of cartridge, turntable, etc. has much more to do with that, but it does provide a -competent- conduit your music to your output stage.
    While others may say, "Warm" or "Musical" or "Wide Image" etc. are the best compliments you can give to an audio product and what one should look for, as an engineer myself, I believe "Competent" is the best praise I can give Shannon's new device. Even saying it is "amazingly competent" adds nothing to the fact that the Puffin does what it sets out to do, at a very reasonable price, and made my entire Vinyl collection more entertaining. I could continue, but suffice it to say, Shannon built a competent device, or more accurately, platform for further engineering enhanced audio or even just features out of an old format, for years to come. We should be so lucky that a skilled engineer shared his baby with us and offers it at a very fair price. If you've read this far, do yourself a favor and try one out and see how it grows."
    Retep
    Steine galen
    Volda
    Ny firmware sluppet.
    Nyttig funksjon for de som leker med EQ eller vil ha rosa støy ut fra riaa.
    BeetleBug
    V1.10 BETA lansert 01.08.19:
    - Added adjustable RIAA eq function
    - Added adaptive Bass Boost
    - Added Pink Noise for Room EQ
    - Added Null to Phase controls
    - Improved Lo filter performance (more rejection)
    - DSP code re-written for speed in assembly SP
    Den lille boksen blir bare mer og mer interessant.
    -BB-
    Retep
    Steine galen
    Volda
    Hører vil egentlig ingen endring på lyden som jeg kan vere sikker på.. Nye høyttalere if ukjent forsterker. Men muligens litt stillere i parti med lav nivå på lyden. Har testa bass boost, det var ikke noe for meg.
    Skal teste pink noise senere ikveld om tida strekker til.
    BeetleBug
    Regnet høljer ned og etter en liten smøreservice på syklene så var turen kommet til å oppgradere min Puffin. Easy peasy og morsomt. Forskjeller? Ja. Støymålingene har aldri vært så bra som dem er nå. Den nye bass boost (loudness) funksjonen fungerer og kan være en morsom funksjon på diverse plater. Tipp, topp - tommel opp!
    Dere finner et interessant og bra verktøy her hvor dere kan leke dere med en simulator som viser hva de forskjellige innstillingene gjør: Home
    -BB-
    Zerostat
    Lillestrøm
    Kunne ikke la være å oppgradere til 1.10beta. Som tidligere er nevnt i denne tråden, så er støymålingene bedre. Jeg har nå 75/99 på 68db gain. Knallbra! Litt flere valg i softwaren som kan virke praktiske å ha. Sånn lydmessig syns jeg hele lydbilde er 'roet' ned et hakk og spesielt stemmer fremtrer nå enda mer naturlig. Eller skal jeg si mer organisk på en litt varm måte. Blir liksom enda mer 'tyggbart' det hele. :D Mange vil nok forbinde 'roen' jeg skrev som svartere bakgrunn. Selv om dette er en beta, så har jeg ikke hatt problemer.
    Veldig fornøyd med Puffin.
    Zerostat
    Lillestrøm
    Oppgradert til 11.1. Hemmm... bedre lyd? Jeg er fortsatt like positiv til Puffin.
    Sank fra 75/99 til dette, uten at jeg hører noe forskjell ifm dette.
    DagS
    Karlstad, Sverige
    Noen som har moddet sin Puffin med digital utgang ennå og kan fortelle om det har noe for seg?
    Zerostat
    Lillestrøm
    Jeg er også spent på dette. Kunnen vært på sin plass å teste ut en high-end DAC.
    En annen sak jeg savner i denne vennetråden er erfaringer av Puffin mot andre phono amp'er. Eks hvor høyt opp i pris matcher den?
    BeetleBug
    Jeg har dessverre ingen andre DAC`er som er dyre nok :)
    Syntes det er interessant med den nye muligheten til å sløyfe den interne Texas Insruments PCM5102 DAC`n og koble den til en ekstern DAC.
    -BB-
    gunnarium
    Rogaland Bryne
    Eg har testet med Rega dac og Abrahamsen V6, lyden blir større med begge.
    Likte best med Abrahamsen sin dac, med denne ble det mer driv/liv i musikken, denne modifikasjonen vil eg anbefale til alle og er en meget enkel jobb.
    BeetleBug
    Her finner dere jobben meget godt beskrevet av konstruktøren:
    http://www.parksaudiollc.com/spdif/spdif.html
    Så er det noen som vet hvor kan vi finne en 121 ohm 1/2W motstand og en 240 ohm 1/2W motstand med +/-5% verdier her i landet uten å måtte kjøpe 10-50 stk av hver?
    -BB-
    DagS
    Karlstad, Sverige
    Morsomt å høre at det kan være verdt jobben!
    Dette er sikkert en enkel sak for de som har svingt loddebolten før, men deler er det kanskje ikke like enkelt å få tak i.
    Selv har jeg måttet bestille RCA-kontakt fra Ebay, med forventet levering mellom 14. november og 31. desember...
    Zerostat
    Lillestrøm
    Vis vedlegget 558490
    Så er det noen som vet hvor kan vi finne en 121 ohm 1/2W motstand og en 240 ohm 1/2W motstand med +/-5% verdier her i landet uten å måtte kjøpe 10-50 stk av hver? Kan sikkert bruke 1/4 eller 1/8. Det var ikke svar på spørsmålet, men jeg skal titte etter hva jeg har.
    -BB-
    Hvorfor trenger en 1/2W motstand? Det holder vel med 1/4 eller 1/8 W.
    Disse er bra: https://www.elfadistrelec.no/no/motstand-240-ohm-vishay-mba02040c2400fct00/p/16059375
    Bjørn.H
    Puffin fås nå med digitalutgang. Jeg vurderer faktisk å prøve en.
    BigSwifty
    Trenger et phonotrinn med volumkontroll for å spille av 78-plater (og kun det). Skal kjøres rett inn i poweramp. Høres ut som om puffin er akkurat det jeg trenger.
    Ere imidlertid ikke særlig teknisk av meg. Er dette relativt lett å sette opp for en med begrenset teknisk forståelse/interesse?
    BeetleBug
    Akkurat like enkelt som andre riiatrinn. Inn og ut. Menyen er intuitiv og enkel den også.
    -BB-
    alibeba
    Øverbygd
    Bestilte en stk. etter å ha lest med fornøyelse på denne tråden
    Kom på 5300,- levert inkl. toll\mva Berget meg akkurat unna kronekrisa
    Han satte verdien ned :) Byttet ut min MF MX VynL og angrer ikke på det et sekund Spilte flott rett ut av eska
    Innstillinger: Air -1 Tilt -1 TF er Tube 2H
    Den har så mange innstillinger at klåfingran for nok å gjøre i tillegg til små mods
    Bruker en AT OC9 XSH, byttet ut en Hana SL og angrer ikke på det De koster det samme og i mine ører er den bedre en Hana SL, men smaken er som baken, delt :)
    Bruker foreløpig en Pro-Ject 2xperience SB og en Technics SL 1500C
    Lyd: God bass, fin mellomtone og flott diskant
    Dette blir artig :)
    DagS
    Karlstad, Sverige
    Ny beta firmware ute nå med "Magic click minimizer, record grading, and enhanced clip monitoring".
    Added Magic pop and click minimizer
    Added Grade which is a record grading function
    Added new clip alerts with asterisk * at Volume (output/DAC clip) & Gain (input/ADC clip)
    Changed TF to fx. Think like "effects" or f(x)
    Lowered 2H Tube distortion (7%THD at full signal)
    Fixed 3H Tape distortion (3.5%THD at full signal)
    Removed 2H&3H from fx
    Moved Noise to fx (PinkNoise)
    Added Out function & merged SPDIF code, though Out:SPDIF is disabled on non-modded Puffins
    Added 25Hz to Low filter and made default
    DagS
    Karlstad, Sverige
    Ny firmware igjen, enda flere spennende funksjoner i Puffin!
    Beta C firmware has been released.
    Changes:
    -Added DeRumble function (200Hz/12dB)
    -Added RoomEQ function (de-mud cut filter: -6dB Q=2.6 at preset frequencies)
    -Doubled the Volume settings with finer adj resolution
    -Updated Levels to include tenths dB resolution for azimuth adjustment
    -Fixed 'Set?' preset loading noise pop (I think?)
    http://www.parksaudiollc.com/V120betaC.zip
    DeRumble is a true rumble filter using the Macaulay Method of summing the low bass to eliminate out-of-phase vertical rumble from the turntable.
    http://www.parksaudiollc.com/macaulay.jpg
    RoomEQ compensates for the room's main resonance that ends up muddying the bass. Just roll with 300Hz or use a free octave RTA on your phone and the Puffin's fx:pinkNoise to find where it is located in your listening space. The RTA apps usually have peak search on as default, so couldn't be easier. I staggered OFFs between the different frequencies (200Hz to 400Hz) so that you could switch back and forth (before and after).
    Lots of changes, so be on the look out for bugs. I think the major changes/additions are over at this point.
    Zerostat
    Lillestrøm
    Er det noen som har moddet den med en digital utgang og fått inntrykk av denne?
    Jonas_H
    Gledelig å lese at den faller i smak hos flere en hos meg.
    Har dere fått benyttet støymålingsfunksjonen til deres Puffin? Og hvis svaret på det spørsmålet er ja, kan jeg spørre hvordan dem ser ut hos dere?
    1) Kun med Puffin påslått.
    2) Med strøm på platespilleren men med armen i sin hvileposisjon.
    3) Når dere spiller musikk.
    -BB-
    I etterspurt rekkefølge. Dette er vel BeetleBug sin gamle.
    Spiller på planar 8
    Sent from my iPhone using Tapatalk
    ragwo
    Mud-fi freak
    El-returen
    Jeg melder meg inn i Lundeklubben!
    Snasen liten sak, spesielt trivelig at en tier i deler gjør at jeg slipper en d/a/d-konvertering. Låter flott gjør den også.
    HiFilivet smiler.
    ragwo
    Mud-fi freak
    El-returen
    Noen som vet om det er en beveggrunn for at riaaen har så få lastalternativer, annet enn kostbesparing? Det begrenser jo pickuputvalget en del.
    stianG
    Shannon mener at det ikke er behov for masse last alternativer så lenge en har eq muligheter. Jeg er tilbøyelig til å være enig. Har mest hell med 47K og justering av tilt og treble. 200Ohm låter mindre dynamisk og "gråere" enn 47K her.
    ragwo
    Mud-fi freak
    El-returen
    Vis vedlegget 579095
    Jeg mottok min på mandag og den ble modifisert før den ble tatt i bruk da jeg kun har digitale innganger på Kii Control. Førsteinntrykket er bra, jeg har ingenting å utsette på lyden eller stabiliteten, men sammenligningsgrunnlaget er ikkeeksisterende da det er ny riaa for meg, jeg har ikke testet analogutgangene, armen er også ny for meg, likeså spilleren. Eneste som ikke er nytt er pickupen.
    ragwo
    Mud-fi freak
    El-returen
    Takk for raskt svar. Har du testet både MM og MC?
    stianG
    Javisst. Har ganske mange pickuper, men akkurat nå er favorittene Stanton 881S MM og Lyra Skala MC. Skala låter klart bedre med 47K last og litt eq.
    knarfar
    Generelt så er 47 MM og 200 MC. Han anbefaler å teste begge uansett for å sjekke hva som låter best. Ellers er det jo Puffin en Sareptas krukke for den som ønsker å tweake. Verdt å merke seg er jo muligheten for å lagre fire oppsett.
    Jonas_H
    Det var solide tall. Hvilken programvareversjon bruker du? Kjører du uten jord?
    Det der var den nest siste programvaren. Nå har jeg 1.2b og dårligere tall 😀 spiller på Rega P8 og den har ingen jord...
    ragwo
    Mud-fi freak
    El-returen
    Noen som har vurdert å flytte inn- og utgangene samt strømpluggen til baksiden av boksen?
    ragwo
    Mud-fi freak
    El-returen
    Prosjekt PIMP my PUFFIN stage 1
    Hei alle Parks Audio venner,
    I kveld var tiden kommet til å ta en nærmere titt på Puffin da jeg utifra noen bilder jeg har sett av Puffin mente jeg kunne gjøre noen enkle inngrep som kanskje ville ha en positiv effekt.
    Tid: ca 2 timer
    Verktøy: unbrako sett med små størrelser, krympestrømper, varmepistol, o-ringer, bitumen, saks
    Drikke: Alkoholfri IPA
    Musikk: Til denne jobben foretrakk jeg Frank Zappa`s fantastiske Hot Rats
    Å åpne Puffin er lett som en plett og riktig unbrako blir levert med i esken den kommer i:
    Vis vedlegget 528947
    Vis vedlegget 528948
    Vis vedlegget 528949
    Før jeg begynte veide jeg den:
    Vis vedlegget 528951
    Og slik ser den altså ut på innsiden:
    Vis vedlegget 528952
    Vis vedlegget 528953
    Vis vedlegget 528954
    Vis vedlegget 528955
    Vis vedlegget 528956
    Vis vedlegget 528957
    Det første jeg gjorde var å isolere metallboksen med bitumen. Jeg varmer alltid bitumen i ovnen først får å gjøre den enklere å jobbe med:
    Vis vedlegget 528958
    Deretter ville jeg forsøke å isolere kretskortet fra topplaten. Den er skrudd rett i toppen og skruene er låst fast med locktite så vær litt obs og evnt bruk litt varme på dem først:
    Vis vedlegget 528961
    Vis vedlegget 528962
    Vis vedlegget 528963
    Vis vedlegget 528964
    Vis vedlegget 528967
    Vis vedlegget 528966
    Vis vedlegget 528965
    Dette veide den etter jobben:
    Vis vedlegget 528968
    Det siste jeg gjorde var å legge en vulkaniseringstape mellom topplokk og boks for å isolere den ytterligere. Her kan man gå enda lengre mener jeg men da må man også benytte lengre skruer til lokket:
    Vis vedlegget 528971
    Vis vedlegget 528970
    Vis vedlegget 528969
    Så merker jeg noen forskjeller? Svaret er ja. Den er blitt enda stillere og er ikke lenger like følsom på de mest ekstreme gain settingene (68 - 72db). Fortsatt kan jeg høre når jeg tapper i ledningene på input siden ved ekstremt høyt volum og høy gain så jeg kommer til å se litt nærmere på dem ved en senere anledning.
    Ser dere noe mer jeg kunne gjort så gi meg gjerne tilbakemeldinger.
    -BB-
    Har blåkopiert deg med hell, knoketesten er bestått og støygulvet sank. Da jeg brukte selvklebende bitumenplater dristet jeg meg til å klistre litt på topplaten også. Eneste som vibrerer litt nå ved aggressiv knoketest er trykknappene og displayet. Får se om jeg gjør noe med det.
