motoren
Skal si du har høy luftfuktighet inne eller dypper du dem i vann?Absolut sikker da helt våde kabler var værst/hårdest.
Forstår jeg deg rett i at du plugger våte kabler til strømnettet? Dristig, må jeg si.En gang havde jeg netop fået nye kabler af Steen Duelund, som havde fået en specialbehandling, så de var våde da jeg prøvede dem. Mange flere detaljer men blev noget skarp i lyden og øretrættende.
Underforstått at høy feedback er å foretrekke?Elektronikk som designes i dag bør designes slik at både ikke-synkroniserte og synkroniserte (med 50Hz) ikke påvirker elektronikken. Dette er ikke hverken vanskelig eller nytt, men koster noen kroner ekstra. Et fellesbegrep på hvor effektivt et apparat er på å ikke la seg påvirke av nettstøy er: PSRR (Power Supply Rejection Ratio)
Fra linken til Ymir:
Mitigation
There are a variety of techniques that can be used to mitigate interharmonics. The most common technique is through the use of passive filters. This approach has been used successfully over many years to control interharmonic and harmonic distortion from arcing loads and cycloconverters. Traditional filtering methods used for harmonic control are not sufficient when interharmonics are present. This is due to the fact that a simple series tuned harmonic filter causes a new parallel resonance at a frequency just below the tuned frequency. When interharmonics are not present this is not a problem, but if they are, significant magnification of the voltage distortion can occur at the parallel resonant frequency. For example, a series tuned fifth harmonic filter has a sharp parallel resonance near the fourth harmonic. To overcome this problem, filters must be designed with damping resistors to minimize the magnitude of the parallel resonance. Unfortunately, this is expensive and results in additional real power losses in the filter. Another difficulty with an interharmonic filter design, is that interharmonic producing loads tend to produce frequency components over a wide range of frequencies. This leads to the design of multi-stage filters which adds to the complexity and cost.
I Hi-Fi apparater over en viss prisklasse bør altså slike filtre være implementert. Det handler om skilletrafoer, spoler, motstander, og regulatorer. I laveffektapparater er ikke dette særlig dyrt og et effektivt filter koster under 200 kroner i deler. Når man ser på prisen på en del Hi-Fi utstyr så kan man egentlig si at det er "feilkonstruert" hvis det ikke klarer å svelge unna støy fra nettet.
Når det gjelder effektforsterkere er ikke dette like enkelt siden man alltid vil ha tap i filtre. I forsterkerkonstruksjoner med lav PSRR og med lav feedback kan nettstøy bli et problem.
I moderne konstruksjoner med medium PSRR og høy feedback vil problemet være mindre/ikke-eksisterende.
Accuphase burde gjøre som bl.a Gryphon og produsere egne strømkabler for å bøte på at deres produkter er feilkonstruerteJeg byttet ut ett par Supra SPC kabler med Wireworld Electra 7 for noen uker siden, og opplever en tydelig forbedring, sannelig tror jeg noen har ett forklaringsproblem ovenfor Accuphase om att deres elektronikk er feil konstruert, hva er det isf som er feil? ikke vet jeg...det låter bedre...
Ja, det er geometrien for å holde induktansen lav. Induktansen er proporsjonal med arealet som omsluttes av strømsløyfen, så større avstand mellom lederne betyr høyere induktans. Tilsvarende er kapasitans proporsjonalt med arealet som selve lederne vender mot hverandre, og omvendt proporsjonalt med avstanden mellom dem. Mindre avstand mellom lederne betyr lavere induktans, men betyr gjerne også høyere kapasitans.Her er kilden til grafen
Slik jeg leser det er det mer at parallelle ledere på HT siden ikke skal ha så stor avstand.
Men uansett, våte kabler er ikke akkurat det man pleier å høre mest om...Nej slet ikke. Da dette ikke var et strømkabel.
Men en dumhed af mig af dimensioner å skrive det i denne tråd som omhandler strømkabel. Det beklager jeg.
Var du ikke fornøyd med Duelund?Det må jeg jo indrømme. Idag bruger jeg ikke Duelund kabler.
Jo, men blir ikke også kabler bedre?Køber stik og kabler og lodder det selv sammen. Køber nogle gange færdige. En del bliver købt på AliExpress. Oplever ikke så store forskelle på kabler idag som tidligere. Men synes det er spændende å prøve nyt. Tror det er fordi elektronikken er blevet bedre.
Alle kabler påvirker lyden, også digitalkabler, og noen ganger kan det være stor forskjell.Jeg har et par Lessloss Firewall 64 filtre. Om de filtrerer er jeg lidt skeptisk overfor. Tror snarere det er farvning fra det tykke kobber i Lessloss. Men synes det er en forbedring. Tror altså også på både signalkabler, højttaler kabler og strømkabler.
Du er inne på noe, jeg har byttet til Accuphase egne xlr kabler det siste året, rimelige mot mye annet jeg har holdt på med...de gjør ikke bort seg, for å si det mildtAccuphase burde gjøre som bl.a Gryphon og produsere egne strømkabler for å bøte på at deres produkter er feilkonstruerte
Good for you!! din kjipe faen...men ikke nødvendigvis for alle andre...og definitivt ingen empirisk sannhetDet er nesten ikke forskjell på kabler når anlegget er på stell. Digitalkabler har ingen forskjeller å koster under en hundrelapp.
Helt enig, jeg er kjip som faen. Utsagnet er forresten basert på egne opplevelser.Good for you!! din kjipe faen...men ikke nødvendigvis for alle andre...og definitivt ingen empirisk sannhet
Det var sagt med litt humor, og håper du legger mest vekt på emojjen i slutten av setningen...Helt enig, jeg er kjip som faen. Utsagnet er forresten basert på egne opplevelser.
Joda forstod det. Vi bør ha smilet på lur her. Tross alt ikke dødsalvorlig dette.Det var sagt med litt humor, og håper du legger mest vekt på emojjen i slutten av setningen...
Påstår du. Uansett oppsett er det stor forskjell på mange kabler er min erfaring. Særlig når det er dårlige plugger. Mange kabler tilslører feil i anlegget, andre viser dem og da skinner også det beste utstyret er min erfaring. Enig i at det er minst forskjell på digitale kabler forutsatt gode kontakterDet er nesten ikke forskjell på kabler når anlegget er på stell. Digitalkabler har ingen forskjeller å koster under en hundrelapp.
Smil på lur Faens gledesdreperJoda forstod det. Vi bør ha smile på lur her. Tross alt ikke dødsalvorlig dette.
Som Øystein Sunde synger, jeg driter i buksa så lenge jakka passer.Smil på lur Faens gledesdreper
Der er i den grad forskel på digitale kabler, synes jeg.Det er nesten ikke forskjell på kabler når anlegget er på stell. Digitalkabler har ingen forskjeller å koster under en hundrelapp.
ja gulost er gulost for noen...Og der er folk der sier det ikke er forskell på vine.
I forhold til å minimere problemer med støy fra nettet ja. Prinsipielt i hvert fall.Underforstått at høy feedback er å foretrekke?
Forleden skiftede jeg Hdmi kablet fra PS Audio ( til et halvt så langt) fra DH Labs. Det er forsølvet kobber. Det gjorde i den grad en forbedring i mellemtone og diskant.Der er i den grad forskel på digitale kabler, synes jeg.
Hvis man har overdrevet meget bass så camouflerer det forskellen på andre ting. Deri vil jeg give dig ret.Det er nesten ikke forskjell på kabler når anlegget er på stell. Digitalkabler har ingen forskjeller å koster under en hundrelapp.
Fair nok men vil blot illustrere at ledermaterialet har betydning for lyden alle steder i kæden.Nå diskuterer vi 'forskjeller' på strømkabler her.
Mener du at det er forskjeller på digitale kabler fins det egne menigheter for slikt.
Ikke at jeg tror @The Shy trenger noen advokat oppi det hele men ut fra målingene jeg har sett ser det ikke ut som overdrevet bass der. Bare rimelig perfekt bass som vi andre uten tilsvarende muligheter kan bare drømme om. Tror ikke dyre kabler er tingen der nei... Men jeg gleder meg til å høre selvHvis man har overdrevet meget bass så camouflerer det forskellen på andre ting. Deri vil jeg give dig ret.
Kan virkelig ikke forestille meg at noen klarer å vise til målbare forskjeller på kabler gjennom en hel verdikjede ut til det akustiske trykket høyttalerne gir i rommet. Det er i så fall første gang så vidt jeg vet.Er jo greit med subjektive inntrykk - men er det noen som prøver å bekrefte sine inntrykk med målinger? F. eks med rew & umic-1 osv? Er ganske enkle verktøy å bruke.
Selv bryr jeg meg ikke om kabler - bakgrunn som elektroingeniør ødelegger moroa der. Men jeg er veldig opptatt av innspillinger og søker bekreftelse ved bruk av Audacity når jeg opplever forskjeller mellom varianter.
