jeg skal prøve med mine maskiner når jeg får de i dag eller i morgen.Umulig å kalibrere, og opptaket ble full av drop outs.....
Til og med jeg vet (Etter Terje-A har lært meg det) at det er forskjellige hoder på 3ES og 6ES. At forfatteren har "svært god kunnskap" finner jeg da vanskelig å tro.Slenger inn et lite "klipp" fra tapeheads i anledning Sony. "Forfatter" er en av de med svært god kunnskap på TH. Leiter absolutt ettetr en 777 slv, men priser ligger i svært høyt Nakamichi leie.
I owned a TC-KA3ES. My understanding of the 6ES is that it is the same deck but for different markets and likely just a different operating voltage. I can?t comment more on the 6ES but I am intimately familiar with the 3ES.
It?s a decent deck overall, well built, excellent fit and finish, and looks beautiful.
However its sonics do not keep up with the rest of it. It sounds clean, but overly clinical and ?hi-fi? like, with an exaggerated treble response that is unnatural. This is what it is like as a playback deck. As a recorder it is okay, actually reasonably good, but nothing more.
A properly tuned and well maintained Nakamichi BX-300 (mentioned in another post above) should take the Sony to the cleaners when it comes to extended and natural HF response, especially with Dolby. It isn?t the ultimate Nakamichi deck by any stretch, but I greatly prefer its Sankyo transport and the Nakamichi Crystalloy heads simply have no equal in the cassette deck industry.
I sold my 3ES some time after buying it. All my other 3-head decks (and some 2-head decks) outperformed it. I bought it new when I worked in retail. I tried a second sample, same thing.
It may float your boat - I am just expressing my own opinion on its sound. However I am definitely not the only one who finds these Sony decks wanting. The best Sony decks - by far - were the early TC-K777 series. Much older, but substantially better sonically and respresented the epitomy of what Sony was capable of engineering.
Vel, hoder, som ikke leverer opp til sammenligningen gjør vel ikke en spiller bedre, selv om de ellers deler det meste?Til og med jeg vet (Etter Terje-A har lært meg det) at det er forskjellige hoder på 3ES og 6ES. At forfatteren har "svært god kunnskap" finner jeg da vanskelig å tro.
Nå blir det enda mer spennende å kjøre dyp testing av 3ES med div bånd siden forfatteren kaller det "my opinion on its sound".
Smaken er som baken og det er svært få som liker flat/korrekt lyd.
http://sportsbil.com/decks/sony.htm
Er vel bare pris, som skiller 3 og 6 versjonen her. Vet at om jeg skal spare til en Sony til, blir det 777. Klarer meg bra med 555ESJ(så langt
TC-K777ES | 1982 | 3 | 15-19 | 0.02 | 61 | 74 | B/C | Manual | No | Closed | 2 | 10.0 | 850 |
TC-KA3ES | 1995 | 3 | 15-22 | 0.022 | 61 | 85 | B/C/S/H | Manual | No | Closed | 3 | 7.6 | 950 |
TC-KA6ES | 1995 | 3 | 20-21 | 0.025 | 61 | 85 | B/C/S/H | Manual | No | Closed | 3 | 7.6 | 850 |
Jepp, opptak på en maskin fra slutten av nittitallet låter fantastisk på spillere som er 20 år eldre.den beste maskinen kassettspillern som ble produsert var vel pioneer i følge konstrøktøren på på den aktuelle modellen. ct95??? men alle mener jo at det de selv har lagd altid er best. så alt man leser på nett må man ta med en klype salt, og rett og slett teste ut selv for og finne ut hva man liker. de elste maksinene i fra 70 og sånt låter som regel varmenere en ei 90's spiller for og si det sånn. men opptakene på nyere spillere låter og fantastisk på eldre maksiner.... jeg liker og bruke ei gammal avspiller og nyere opptaker![]()
hopp over sony da vil jeg heller anbefale ei kx1200 Frequency Response: 20Hz to 24kHz (Metal tape) men ulempen ikke noe dolby s. dog dbx.
TC-K777ES 1982 3 15-19 0.02 61 74 B/C Manual No Closed 2 10.0 850
TC-KA3ES 1995 3 15-22 0.022 61 85 B/C/S/H Manual No Closed 3 7.6 950
TC-KA6ES 1995 3 20-21 0.025 61 85 B/C/S/H Manual No Closed 3 7.6 850
"Leverer opp til sammenligningen"?? Kan du forklare den?
Hodene på 3ES har en F.R. på 15-22khz mens 6ES klarer "bare" 20-21khz......+/- 3db
I min verden er det noe bedre tekniske data....hørbart? neppe.
Ok, da har vi enda en myte som trenger en teknisk forklaringJepp, opptak på en maskin fra slutten av nittitallet låter fantastisk på spillere som er 20 år eldre.![]()
Er flere variabler her, men jeg har mistanke om at lydhoder av Ferrite kan gi en litt annen lyd enn hoder av Sendust og Lazeramorphous. Og elektronikken betyr også noe.Ok, da har vi enda en myte som trenger en teknisk forklaring
Sånn rett fra hofta høres dette ut som forskjeller i EQ?! Forutsatt innstillinger forøvrig er kalibrert til kassett.
En F.R. test rett ut fra spilleren vil jo kunne avdekke hva dette er snakk om.
Har testa en av disse å jeg må bare si at de er ala Tandberg 3034, ser fin ut, menn låter ike bra. De har egenstøy pga "pynten" å gir masse ugjevn gange. Har åsså en Thorens slik, den er ike slik. Styr unna vis du skal ha slike til optak! Kan bare brukes til pyntInsprert av kjellR, så handla jeg åsså slike med spole. Syns de er töffe
Vis vedlegget 803447
Gammelkjent problem. Speciellt Sony´s F&F heads og Akai deres Glass & X-tal Ferrite.Er flere variabler her, men jeg har mistanke om at lydhoder av Ferrite kan gi en litt annen lyd enn hoder av Sendust og Lazeramorphous. Og elektronikken betyr også noe.
ferdig innspilte har verdilitt utenom kassetter... fikk en hel haug minidisker i dag og ei sony opptaker gratismaskinen er virker til og være noe av det gromme bærbare. funker gjør den og.
Vis vedlegget 804826 synd minidisk aldri slo helt ann liker det conseptet bedre en cd. ..
ja det er som å fiske, en vet aldri hva en får med seg på båndet. på disse er det opptak fra en menighets-preken da er det bare til å legge dem i skuffen klar for opptakjoa alitd morsomt og gå gjennom noe man ikke vet hva er. noen ganger får man seg en overaskelse... på en brukt kassett jeg kjøpte en gang var det live opptakk fra øvelse eller noe fra en kjent jazz musiker. når man finner slikt er det litt morro. art van damme var navnet her. fått noen kassetter fra fader'n sin ungdoms tid når han spilte i band var morro og høre det og. + div andre artister. utrolig mye rart kan gjemme seg på et medium![]()
Som jeg trodde. Og da ble det bekreftet - takk.Har testa en av disse å jeg må bare si at de er ala Tandberg 3034, ser fin ut, menn låter ike bra. De har egenstøy pga "pynten" å gir masse ugjevn gange. Har åsså en Thorens slik, den er ike slik. Styr unna vis du skal ha slike til optak! Kan bare brukes til pynt
Putta in en av disse Maxel fra PK å det var mye bedre. Helt stabil å fin i lyden
hvis det er den produsert i utlandet så fikk den pes kun for detSom jeg trodde. Og da ble det bekreftet - takk.Så kommer aldri til å putte "pynte kassetten" inn i spilleren. Kun til pynt...
Kjöpte du mange? Jeg kjöpte bare to å det kosta runt 200 så jeg gråter ike. Denna derimot går stile å gjevnt Sikert ike ekte vareSom jeg trodde. Og da ble det bekreftet - takk.Så kommer aldri til å putte "pynte kassetten" inn i spilleren. Kun til pynt...
Dette er veldig bra spiller, Pioneer har mange veldig fine modeller. Jeg hadde en Pioneer forsterker og tuner fra den serie, noe med A-717 i navnet tror jeg. 100 watt med bikube design innvendig. Brukte den på Carlsson OA-50.3 høyttalere.Gammelkjent problem. Speciellt Sony´s F&F heads og Akai deres Glass & X-tal Ferrite.
Disse har altid fået skyld for en litt kølig klang på deres opptak i forhold til gammeldags alm. og sendust.
På spole-siden det samme. Bogen´s hoveder som bl.a. benyttes hos B&O og Revox har altid "fået skyld for" varm og naturlig klang.
Desværre slites de veldig fort.
En annen ting....... Spiller ikke så verst denne. Fandt et gammelt Denon DXM, hvor det var gjort et opptak med Police engang på 80-tallet.
Faen.... som det låter bra
Vis vedlegget 804847
Ja... de gjorde fine ting dengangen. Det er bikube-chassis/bunnplate på CT-757 og.Dette er veldig bra spiller, Pioneer har mange veldig fine modeller. Jeg hadde en Pioneer forsterker og tuner fra den serie, noe med A-717 i navnet tror jeg. 100 watt med bikube design innvendig. Brukte den på Carlsson OA-50.3 høyttalere.
Da må du ha et azimuth bånd, hvilken spiller er det?
Du kan kjøpe på bayen også men mange av de er bare noe folk har laget hjemme selv så ikke til å stole på 100%.GennLab Azimuth Alignment Cassettes
www.gennlab.com
Om du vil ha samme azimuth på alle spillere du har, så bånd tatt opp på en maskin spiller fint på en annen må du gjennom hele mølla, opptakshode og avspillingshode må justeres på alle men om du gjør justeringer betyr jo det at alle bånd du har tatt opp ikke lyder bra lenger.
Om du har én spiller du vil bruke som referanse kan ta opp en 15khz tone på denne, sett båndet i spilleren du har kjøpt og juster for høyest mulig signal på utgangen men om det er en trehoder maskin må du fortsatt justere innspillehodet også.
Her f.eks. en DIY for Nakamichi https://naks.es/calibration-tutorial/
Jeg er skeptisk til 100 minutters, den tapen er utrolig tynn og kan gi trøbbel, både salat og "gjennomslag" ved opptak.Er 100 minutters bånd generelt billigere enn 90 minutters? Ser på 'Bay' at ellers like bånd er billigere i 100 min. utgavene. Noen som vet / kan bekrefte?
..så derfor den kanskje ikke er så populær - ergo billigere?Jeg er skeptisk til 100 minutters, den tapen er utrolig tynn og kan gi trøbbel, både salat og "gjennomslag" ved opptak.
Det er nok en sannsynlig årsak, jeg kjøper ikke flere 100 tape...så derfor den kanskje ikke er så populær - ergo billigere?
Er 90 minutters til å "stole på"? Har en del av de og håper de ikke steller til "leven".
Men i Japan ble det solgt mange som er i andre lengder. Disse dukker jo opp på eBay og andre steder nå. Jeg har noen av 46,50 og 54.60 og 90 er mest brukt.
Stille hode på en 3hoders trenger du en 400mz (tlf app generert og inn i rec) tone på opptak og sette spilleren på tape og justere til VU viser høyest
440a har vel egen azimut tone og skrue under deksel til høyre for kassett luke?60 og 90 er mest brukt.
