Gjallarhorn Audio
Angående rensevæske, så følger det nå med (fra og med januar i år) 2 forskjellige rensevæsker.
Den ene heter "Record Rinse Aid" og er det samme produktet som tidligere fulgte med, men da under navnet "Record Cleaning Fluid". Den andre heter "Record Cleaning Fluid" og er beregnet på meget skitne plater.
Her er tekst hentet fra Degritter:
Record Rinse Aid
The Record Rinse Aid is designed for relatively clean or moderately dirty records and is perfect for everyday cleaning. The fluid helps remove greasy particles and shortens record drying time. The recommended amount is only 1-2 ml per water tank, so one bottle will last for 50 - 100 tanks. Record Rinse Aid contains anionic surfactants, which are safe for vinyl records. The fluid is manufactured for Degritter by Mayeri Industries AS, Estonia.
The Record Cleaning Fluid is recommended for cleaning really dirty records. The fluid is designed to enhance the ultrasonic cleaning properties and removes greasy particles with ease. The recommended amount is 5-10 ml per water tank, so one bottle will last 10 - 20 tanks. The Record Cleaning Fluid contains organic solvents, surfactants, and rinse aids and it is safe for vinyl records. The fluid is manufactured for Degritter by Alconox Inc, USA.
Record Rinse Aid
