Denne var kjempetøff. Har du noe mer info?
Klipp og lim fra ei Kina side.
1.Aluminum alloy material
2. Professional decoding chip
It is decoded by the American BB company's PCM1792 chip, which is praised by the majority of enthusiasts, with a specification of 24bit / 192KHz. In addition to common OGG, MP3, WAV, WMA and other formats, it also supports lossless APE, PlAC
3. The analog output uses two Russian gold-footed 6922EH vacuum tubes. The transistor output circuit uses a carefully selected pair of field effect tubes and powerful capacitors.
4.With optical fiber and coaxial digital signal output
C-30CD has optical fiber and coaxial digital output interface, which can be connected to a digital / analog converter (DAC)
5. True balanced output
C-30CD can provide true balanced output. The gold-plated pin 6922EH is used for single-ended amplification and output.
6.PHILIPS digital servo system
Years of CD broadcaster design and production experience, redesigned movement level and suspension system
7. High quality transformer specially developed for this machine
Analog circuits and digital circuits use independent power transformers and rectification and voltage stabilization systems to supply power. Low-leakage, high-efficiency toroidal power transformers specially developed for this machine are used.
Product Specifications
Output level: 2.3V ± 0.5dB (RCA) 4V ± 0.5dB (BALANCE)
Power consumption: 30W
Dynamic range: 120dB
Frequency response: 20Hz ~ 20kHz ± 0.5dB
Use of electronics: Tube gold plated 6922EHX2
Distortion plus noise: -70dB
Volume: 440mm * 390mm * 130mm
Signal to noise ratio: 92dB
Net weight: 15.5KG
Output terminal: one RCA, one BALANCE, one coaxial, one optical fiber
