Elektriske biler er vesentlig mer effektive en fossilbiler. Og vi må også huske på at strømmen vi henter fra nettet blir stadig mer og mer fornybar.
Have you heard or read that electric cars are no more efficient than gasoline or diesel powered cars? That myth is one of the easiest to explode. Quite simply, it's not even remotely true.
cleantechnica.com
Bl.a.
“Consider the Tesla Model S, which has an available 85 kWh battery and a 265 mile range. Consider a similar gas-powered car, which gets 35 mpg. Gasoline contains about 33 kWh of energy per gallon. The Tesla uses 320 Wh/mile of energy (85 kWh/265 miles). The gas powered car uses 940 Wh/mile of energy (33 kWh/35 miles). Once the energy is on board (not counting the efficiency of the power generation, oil refining, or charging), the Tesla is using only about a third as much energy as the comparable gasoline-powered car.”
