Yes, og hvis du ikke er skremt nok så kan du sjekke ut denneArtikkelen er virkelig skremmende.
https://www.vanityfair.com/news/2017/07/department-of-energy-risks-michael-lewis
Men den er ikke det minste overraskende. Dette visste vi fra før, om ikke i like stor detalj.Artikkelen er virkelig skremmende.
The potential innocent explanations for the president's behavior over the last two years have been steadily stripped away, piece by piece. Special counsel Robert Mueller and investigative reporters have uncovered and assembled a picture of a presidential campaign and transition seemingly infected by unprecedented deceit and criminality, and in regular—almost obsequious—contact with America’s leading foreign adversary.
A year ago, Lawfare’s Benjamin Wittes and Quinta Jurecic outlined seven possible scenarios about Trump and Russia, arranged from most innocent to most guilty. Fifth on that list was “Russian Intelligence Actively Penetrated the Trump Campaign—And Trump Knew or Should Have Known,” escalating from there to number 6 “Kompromat,” and topping out at the once unimaginable number 7, “The President of the United States is a Russian Agent.”
After the latest disclosures, we’re steadily into scenario 5, and can easily imagine number 6.
Nå, mindre enn én uke senere har så mange fler skjeletter falt ut av skapene at artikkelforfatteren konkluderer slik:Put together all the clues, and Occam’s Razor comes to mind: The most obvious scenario is the most likely scenario. And the most likely scenario now is that there was no division between the apparent Trump-Russian collusion on business matters and in the election.
The coincidences are piling up. The conversations are piling up. Mueller’s evidence is clearly piling up as well.
“The completely inconceivable idea that . . . the president of the United States is an active agent of Russian intelligence, no longer seems completely unthinkable.”
Individual #1 begynner å ligne på worst case #7.“We have rapidly entered a territory of the worst-case scenario for the United States here, where the thing that you most try to avoid in politics is a situation where the head of state of your country can be blackmailed by a foreign power or foreign adversary,” Graff told me during the latest episode of “Cape Up.”
Og jeg minner om at Trump insisterte på å snakke på tomannshånd med Putin, i Helsinki ...Men den er ikke det minste overraskende. Dette visste vi fra før, om ikke i like stor detalj.
Wired diskuterte worst case scenarier 12 desember:
https://www.wired.com/story/manafor...mp-mueller-investigation-worst-case-scenario/
https://www.washingtonpost.com/opin...-worst-case-scenario-garrett-graff-thinks-so/
“The completely inconceivable idea that . . . the president of the United States is an active agent of Russian intelligence, no longer seems completely unthinkable.”Individual #1 begynner å ligne på worst case #7.“We have rapidly entered a territory of the worst-case scenario for the United States here, where the thing that you most try to avoid in politics is a situation where the head of state of your country can be blackmailed by a foreign power or foreign adversary,” Graff told me during the latest episode of “Cape Up.”
"Nyttig idiot" passer nok bedre enn "Russisk agent", ja.Og jeg minner om at Trump insisterte på å snakke på tomannshånd med Putin, i Helsinki ...Men den er ikke det minste overraskende. Dette visste vi fra før, om ikke i like stor detalj.
Jeg tror ikke Trump er russisk agent. Men noe var galt fra første øyeblikk. Her får du verdens beste etterretningsapparat plassert i dine hender -- NSA, CIA, DHS, NRO, DIA, pluss samtlige militærgrener. Og hva gjør du? Du angriper dem, setter spørsmålstegn ved deres lojalitet, anklager dem for å være i egen eller demokratenes tjeneste. Du sparker føderalt ansatte som har lang og tro tjeneste bak seg, mange republikanere. Du æreskjeller dem. Du presterer det hinsides tåpelige å få dine tilhengere til å begynne å ha mer sympati for Putin og Russland enn for eget lands ordensmakt og etterretning.
Det gjør du når du enten er komplett idiot eller i en tilstand av panikk. Jeg tror det siste. De innså klemmen de befant seg i da Trump vant valget og i panikk ble det lagt en hastig plan om hvordan man skulle så tilstrekkelig tvil, fordi man fryktet at etterretningen skulle stå på døren dag 1. (Omtrent som da bankledelsen på Wall Street regnet med å bli arrestert dagen etter at Obama ble innsatt som president, uten at det skjedde).
Av respekt for institusjonene og maktfordelingen har man arbeidet møysommelig, endevendt alt og forberedt en tiltale som blir så omfattende og så knusende at man håper å unngå det Dr. Dong spør om -- åpen og væpnet konflikt -- når Donald John Trump avsløres. Men for dem som lot seg lure, fra Sean Hannity og ned til Fjernis, blir det tunge tak. Og det er liten grunn til å stusse over hvorfor det er umulig å få annet enn skrullinger til å arbeide for denne presidenten.
Kanskje «psykoanalysere» er feil ord. Analysen i sitatet er god og kanskje spot on, men det jeg likevel reagerer på er at man absolutt skal «forstå» disse Trump-kultistene. Det blir litt som når svenske sosionomtanter skal forstå gjengmedlemmer og IS-sympatisører i Rosengård. Det vipper lett over til å unnskylde. Man kan forstå det så mye man vil, men det er likevel galt å tenne på parkerte biler og hive håndgranater inn av vinduer. Det finnes heller ingen unnskyldning for å la seg forføre av en demagog.Synes du dette er psykoanalysering, Asbjørn? (Det var det siste som falt meg inn.)
Det er nesten som du sier: Den som ikke ser verden som meg er ikke helt frisk.
Det er vel ganske sjukt å si?
Jeg deler ovenstående oppfatninger fullt ut, men:Kanskje «psykoanalysere» er feil ord. Analysen i sitatet er god og kanskje spot on, men det jeg likevel reagerer på er at man absolutt skal «forstå» disse Trump-kultistene. Det blir litt som når svenske sosionomtanter skal forstå gjengmedlemmer og IS-sympatisører i Rosengård. Det vipper lett over til å unnskylde. Man kan forstå det så mye man vil, men det er likevel galt å tenne på parkerte biler og hive håndgranater inn av vinduer. Det finnes heller ingen unnskyldning for å la seg forføre av en demagog.Synes du dette er psykoanalysering, Asbjørn? (Det var det siste som falt meg inn.)
Å støtte den karrierekriminelle Donald J Trump i hans kontinuerlige forsøk på å rive ned prinsippene om rettsstat, likhet for loven og maktfordeling er ikke forståelig. Det er hooliganisme. Å velge ham til president er et angrep mot grunnprinsippene USAs uavhengighetserklæring og grunnlov er bygget på. Historien kommer ikke til å være nådig mot trumpistene.
https://www.nytimes.com/2018/12/17/opinion/republican-apparatchiks-deep-state.html?But as I said, it’s not just the courts. Even as Trump and his allies spin fantasies about sabotage by the “deep state,” the reality is that a growing number of positions in government agencies are being occupied by right-wing partisans who care nothing, or actively oppose, their agencies’ missions. The Environmental Protection Agency is now run by people who don’t want to protect the environment, Health and Human Services by people who want to deny Americans health care.
The same takeover by apparatchiks is taking place in politics. Remember when the role of the Senate was supposed to be to “advise and consent”? Under Republican control it’s just plain consent — there is almost literally nothing Trump can do, up to and including clear evidence of corruption and criminality, that will induce senators from his party to exercise any kind of oversight.
So how do people who think and behave this way respond when the public rejects their agenda? They attempt to use their power to overrule the democratic process. When Democrats threaten to win elections, they rig the voting process, as they did in Georgia. When Democrats win despite election rigging, they strip the offices Democrats win of power, as they did in Wisconsin. When Democratic policies prevail despite all of that, they use apparatchik-stuffed courts to strike down legislation on the flimsiest of grounds.
As David Frum, the author of “Trumpocracy,” warned a year ago: “If conservatives become convinced that they cannot win democratically, they will not abandon conservatism. They will reject democracy.” That’s happening as we speak.
Føler at det er feil bruk av ordet "conservatives".Krugman oppsummerte greit nylig. GOP består i dag av "movement conservatives" med ambisjoner om å dekonstruere den føderale staten, fjerne skatter og reguleringer, samme hva det ellers koster. Jeg gjør to uthevelser. Man har klart å lure "vanlige" amerikanere til å være med på dette, ved å gjøre "deep state" og "msm" til felles, interne fiender -- når det går opp for vanlige velgere hva de er blitt lurt til å gjøre, ren selvskading, vil det faktisk tjene formålet til dem som i dag styrer blant republikanerne: de vil få den uroen de trenger for å kunne fortsette sitt angrep på demokratiet.
Som sagt, fra hvem som helst:Trump har som andre patologiske narcissister et umettelig behov for å bli skrytt av, og hvis ingen andre skryter av ham så skryter han i eksesser av seg selv i desperat jakt etter anerkjennende nikk fra andre. Hvem som helst.
Vi må prøve å holde det deskriptive unna det normative. Hvis ikke blir hele det samfunnsvitenskapelige prosjekt til en meningsløshet. Jeg er ikke uenig i at det kan hende at det å forstå noe bekker over i å unnskylde, men den overskridelsen skjer i en kontekst hvor forklaringen/forståelsen brukes på en spesiell måte. Jeg anser den som noe som har opphav i en pragmatisk horisont.Kanskje «psykoanalysere» er feil ord. Analysen i sitatet er god og kanskje spot on, men det jeg likevel reagerer på er at man absolutt skal «forstå» disse Trump-kultistene. Det blir litt som når svenske sosionomtanter skal forstå gjengmedlemmer og IS-sympatisører i Rosengård. Det vipper lett over til å unnskylde. Man kan forstå det så mye man vil, men det er likevel galt å tenne på parkerte biler og hive håndgranater inn av vinduer. Det finnes heller ingen unnskyldning for å la seg forføre av en demagog.Synes du dette er psykoanalysering, Asbjørn? (Det var det siste som falt meg inn.)
At de som ikke bare videreformidler Donalds argumenter, men selv står inne for dem - f. eks. løgnene om antall oppmøtte på innsettelsen - er medskyldige i løgnene og vil faenskapet, er en annen sak. Vi har jo eksempel her i tråden.
De kaller seg det, men dette er et radikalt reaksjonært program som har fint lite med konservatisme i tradisjonell betydning å gjøre. Denne gjengen var de som Edmund Burke advarte mot og de som de amerikanske grunnlovsfedrene fryktet. For Burke’s del førte bekymringen for demagoger og lett-ledet mobb til en grunnleggende skepsis til altomfattende demokrati. Han så Overhuset med nedarvet adel som en nødvendig stabiliserende faktor for å unngå at demokratiet lot seg vippe over i tyranniet. For grunnlovsfedrene var det viktig å sikre en statsform med maktfordeling og «checks and balances». De gikk så langt som å grunnlovsfeste at ikke hele Kongressen velges på en gang og at presidenten velges av et valgmannskollegium heller enn direkte, nettopp for å bygge inn litt friksjon mot oppiskede stemningsbølger i velgermassen.^ Det får du fortelle til de mange ledende amerikanske konservative som anser seg å være "movement conservatives". Man kan sikkert argumentere med at det blir like absurd som når Nord Korea påstår det er en demokratisk republikk, men i USA har det ført til at man på noen tiår har kapret institusjonene.
https://en.wikipedia.org/wiki/Movement_conservatism
Det er kanskje derfor «true believers» ikke kunne fatte hva som traff Flynn i retten i går. Dommer Sullivan «heiet ikke på et lag», men holdt noen som avla en ed på å verne om grunnloven ansvarlig for nettopp det.Historically, Reflections on the Revolution in France became the founding philosophic opus of Conservatism when some of Burke's predictions occurred: the Reign of Terror under the new French Republic executed thousands, (including many nuns and clergy) from 1793 to 1794 to purge so-called counter-revolutionary elements of society. That, in turn, led to the political reaction of Gen. Napoleon Bonaparte's government, which appeared to some to be a military dictatorship. Burke had predicted the rise of a military dictatorship and that the revolutionary government instead of protecting the rights of the people would be corrupt and violent.
Instead, the 71-year-old *veteran jurist used his platform to puncture conspiracy theories that paint Flynn as a victim of deep-state persecution. And he reminded the country of a few simple creeds commonly held in courthouses but increasingly dismissed by the president’s allies: Lying to the FBI is against the law. Breaking the law is bad. People who work in the White House are supposed to be held to a higher standard.
“This is a very serious offense,” Sullivan told Flynn, even after Mueller’s prosecutors told the judge they agreed that Flynn should face little to no incarceration because he cooperated with their investigation.
The judge pointed to the American flag behind his bench and told the decorated combat veteran that he had undermined it: “Arguably, you sold your country out.”
https://www.washingtonpost.com/poli...-out-prison-heres-why-he-may-face-five-years/Sullivan’s angry lecture from the bench — and his suggestion that he was willing to throw Flynn in jail — injected a moment of high drama into the long-running investigation and served as a reminder of the seriousness of the allegations that launched the special counsel investigation.
The move was in keeping with Sullivan’s lack of tolerance for official misconduct, lawyers familiar with his court said.
“Judge Sullivan usually gives prosecutors a hard time, not because they’ve necessarily done anything wrong, but because he holds the government to a very high standard,” said Glenn Kirschner, a former federal prosecutor who has often appeared before Sullivan. “But today, it played out to the disadvantage of the defendant. And why? The defendant was a high-ranking government official who engaged in egregious conduct. And Judge Sullivan turned his wrath on the defendant.”
Former federal prosecutor and Georgetown law professor Paul Butler told The Washington Post in an interview that plea bargains are all-or-nothing operations and “concern about equal justice under the law is in Sullivan’s DNA.”
“A typical defendant who pled guilty and then tried to backtrack, like Flynn, would lose credit for cooperation because he’s failed to accept responsibility,” Butler said.
.The White House claimed a major legislative victory after the Senate on Tuesday night overwhelmingly approved a bipartisan criminal justice reform bill backed by President Trump
A newly obtained document shows President Donald Trump signed a letter of intent to move forward with negotiations to build a Trump Tower in Russia, despite his attorney Rudy Giuliani claiming on Sunday the document was never signed.
CNN's Chris Cuomo obtained a copy of the signed letter of intent that set the stage for negotiations for Trump condominiums, a hotel and commercial property in the heart of Moscow. The letter is dated October 28, 2015, and bears the President's signature.
When asked on Sunday about the letter, Giuliani incorrectly told CNN's Dana Bash that it had not been signed.
"It was a real estate project. There was a letter of intent to go forward, but no one signed it," Giuliani told Bash.
The non-binding document is also signed by Andrey Rozov, owner of I.C. Expert Investment Co., the Russian firm that would have been responsible for developing the property.
Trump did not tell the public during the 2016 presidential campaign that his company explored the business deal with Russia and instead repeatedly claimed he had "nothing to do with Russia." But the project, which was ultimately scrapped, would've given Trump's company a $4 million upfront fee, no upfront costs, a percentage of the sales and control over marketing and design. The deal also included an opportunity to name the hotel spa after Trump's daughter Ivanka.
https://kirkcenter.org/reviews/buckley-and-individualist-conservatism/Following World War II, conservatism was disdained by both Republican Party stalwarts, who tried to elect people like the liberal Wendell Willkie, and intellectuals such as Arthur Schlesinger Jr., who thought conservatism little more than irrational prejudice. But these were outside forces. Bogus says the real controversies were within conservatism itself. He focuses on the crucial years between 1951, when the young Buckley published his blockbuster God and Man at Yale, and 1968, the annus terribilis that both brought the counterculture to power and energized the conservative legions, eventually resulting in the election of Ronald Reagan, who had himself been converted from New Deal liberalism through his reading of National Review.
In those years, conservatism was divided among the traditionalists, libertarians, and the ex-Communists. The traditionalists were represented politically by Robert A. Taft and intellectually by the influential critic Russell Kirk, an early National Review contributor and author of the foundational text The Conservative Mind (1953). Kirk—whom Bogus treats respectfully here, better than most liberal commentators—advocated a conservatism, derived from Edmund Burke, that favored gradual change, a small role for government with an emphasis on preserving and strengthening local communities, and an allergy to foreign entanglements.
The implacable Frank Meyer was both ex-Communist and libertarian. Though they vehemently disagreed on conservatism’s true nature, both Kirk and Meyer became writers for National Review. Bogus recounts Buckley’s careful courting of these rivals to bring them under the National Review umbrella. Buckley was able to unite these schools because he was himself the embodiment of conservatism’s various strands: both libertarian and traditional, religious and cosmopolitan, elitist yet opposed to the liberal knowledge classes. Thus when Buckley pronounced certain ideas beyond the pale—most famously, his ostracism of the John Birch Society and the Ayn Randians—they stayed there.
By the time the cultural revolution arrived in 1968, because of Buckley “[c]onservatism was no longer a philosophy about community—a hallmark of Burkeanism; it had become a philosophy of individualism. Conservatism was no longer wary of military adventurism,” a position that would be better known as neoconservatism. More than any other figure, Bogus contends, Buckley transformed a conservatism into a political program based on the individual and a strong nationalism.
Bogus unearths the roots of Buckley’s libertarian streak in this example of his father, Will Buckley, who went to Mexico penniless and came back successful. Bogus finds that the younger Buckley derived a strong sense of individualism from this history, which initially overcame the religious and traditionalist elements in his conservatism. This sometimes translated into shallow critiques of traditionalist thinking, or his holding on too long to positions inconsistent with conservatism, and even of his individualist brand, such as prolonged military actions.
Bogus, however, slightly overstates his case. Buckley became more Burkean as he grew older—acknowledging error in supporting the second Iraq war, for example—and he always maintained a strong affinity for conservative ideas about community, tradition, and the family.
Just precis. Poenget er at Smith først og fremst var moralfilosof. I forbifarten kom han i skade for å oppfinne økonomifaget. Første avsnitt i The Theory of Moral Sentiments ser ikke ut som en direkte beskrivelse av Donald J Trump, men Smith var nok en optimist:En kort sammenfatning -- Buckley selv fant veien delvis tilbake til Burke på slutten av sitt liv, men amerikansk konservatisme er individualistisk og ekskluderende, ikke kommunitær og inkluderende. Hva gjelder Adam Smith, er jeg av den oppfatning at ingen bør referere til ham før de har lest A Theory of Moral Sentiments. "A theory of what?" pleier amerikanere å si til meg.
Forøvrig, Edmund Burke var liberal Whig, ikke kongetro Tory, men hans idéer om gradvis utvikling av bestående samfunnstrukturer definerte moderne konservatisme. De amerikanske uavhengighetsforkjemperne var godt kjent med hvor han sto, ettersom Burke tok deres side i 1774-75. Uavhengighetserklæringen reflekterer Burke's forsiktighetsprinsipp.How selfish soever man may be supposed, there are evidently some principles in his nature, which interest him in the fortunes of others, and render their happiness necessary to him, though he derives nothing from it, except the pleasure of seeing it. Of this kind is pity or compassion, the emotion we feel for the misery of others, when we either see it, or are made to conceive it in a very lively manner. That we often derive sorrow from the sorrows of others, is a matter of fact too obvious to require any instances to prove it; for this sentiment, like all the other original passions of human nature, is by no means confined to the virtuous or the humane, though they perhaps may feel it with the most exquisite sensibility. The greatest ruffian, the most hardened violator of the laws of society, is not altogether without it.
Prudence, indeed, will dictate that Governments long established should not be changed for light and transient causes; and accordingly all experience hath shewn that mankind are more disposed to suffer, while evils are sufferable than to right themselves by abolishing the forms to which they are accustomed.
Værsågod, Fjernis. Utkast skrevet 24 januar 2017 og ferdigstilt 15 februar 2017:Ellers så får vi se hva som kommer ut av Flynn saken:
https://www.document.no/2018/12/16/en-rettferdig-dommer-kan-vaere-nok/Etter hvert FBI-avhør skal det skrives en rapport, en såkalt 302. Det skal skje tett på avhøret for størst mulig presisjon. Men i Flynns tilfelle er det noe merkelig. Det ble skrevet en 302 rett etterpå, men dette vil ikke Justisdepartementet utlevere. Det FBI har servert er skrevet i august 2017, syv måneder senere. Her er noe som ikke stemmer.
https://edition.cnn.com/2018/12/17/politics/mueller-memo-doc-flynn/index.html
Som eksempel på hvor vanskelig konservative har det på amerikanske universiteter trekker Toje fram studenter som ikke tør gå med Trump-caps. Det er et veldig rart sted å begynne et forsvar for konservatismens akademiske verdi. Altså, enten er amerikansk konservatisme nå en Trump-ideologi, _eller_ så er den verdifull. Den kan ikke være begge deler. Det er bra med akademikere som forstår og respekterer den konservative idetradisjonen. Men da går du da ikke rundt med MAGA-caps. At studenter bør kunne flagge sin støtte til Trump er et ytringsfrihetsspørsmål. Det handler om mangfold og åpenhet. Men Toje vil knytte dem til en verdifull konservativ tradisjon som tilfører universitetene noe viktig. Det gjør de jo ikke. Og de som virkelig burde bli fornærmet av en slik kobling er de som mener at en slik verdifull tradisjon finnes.
Mitt syn er at det finnes mange verdifulle konservative ideer som flere burde kjenne til. Mye av det jeg har skrevet de siste årene, spesielt de to siste bøkene, har gjort bruk av disse ideene. Men jeg er usikker på om det finnes en verdifull og levende konservativ ideologi eller tradisjon. Det er opp til de som mener de tilhører den å bevise at de har noe viktig å komme med. Det jeg ser i stedet er folk som heller mer mot liberalisme eller nasjonalisme, som bruker ordet konservativ som et smykke. Det gir mer på en måte mer alvor, dybde og verdighet å være liberalkonservativ enn at man egentlig bare vil ha en fri økonomi, eller å være nasjonalkonservativ enn at man egentlig bare avskyr venstresiden og er redd for innvandring.
Både på sitt beste og sitt verste har konservatismen noe elitistisk over seg. Den står i et motsetningsforhold til populisme, liberalisme og nasjonalisme. Det er en tradisjon for folk som flirer av svindlere som Trump, himler med øynene over politiske massemønstringer, og forsvarer fordommene sine i møte med det tilsynelatende rasjonelle. Det er et åpent (men spennende) spørsmål hvor mye verdi denne tradisjonen har hatt og kan ha politisk. Men i dag må vi også spørre om konservatisme i det hele tatt finnes lenger, eller om alt vi har er et fint ord som noen liker å knytte seg mot.
Hvis den finnes, representerer den iallfall ikke "halvparten av talentene i samfunnet". Det blir et dobbelt kuppforsøk. Først kuppe ordet konservatisme på vegne av noe som mest sannsynlig er noe annet, deretter kuppe hele høyresiden på vegne av noe som bare er en fløy.
Like ugjennomtrengelig, et forseglet dokument relatert til Cohen og en sak for statsadvokaten i New York:So the court’s ruling in In re Grand Jury Subpoena is effectively the first peek at a very secret case. The court outlines the contours of the case in the judgment’s first paragraph: the appellant is a corporate entity (“the Corporation”) that is owned by a foreign country (“Country A”) and is seeking to quash a subpoena it received from a grand jury in an undisclosed criminal matter. The Corporation made two arguments in support of this effort before the district court: first, that it is entitled to sovereign immunity; and second, that complying would place it in violation of Country A’s own laws. The district court rejected both arguments and—when the Corporation still refused to comply—held the Corporation in contempt, imposing a fixed monetary penalty on it so long as it refuses to comply. The Corporation then appealed to the D.C. Circuit, where it also argued that the district court lacked subject-matter jurisdiction over the issue. In today’s judgment, the D.C. Circuit rejects all three arguments and affirms the district court’s decision.
Det er tydeligvis mye mer som etterhvert vil bli kjent om Trumps og Cohens ulike affærer, som om det ikke var nok allerede.The sealed document was filed in a case brought against Cohen by the U.S. Attorney’s Office for the Southern District of New York.
In that case, Cohen pleaded guilty to tax evasion, making false statements to a bank, and to campaign contribution crimes related to the payments of hush money to two women who claim they had affairs with Trump.
In the case filed by Mueller, Cohen admitted lying to Congress about the extent of Trump’s knowledge of a plan to build a Trump Tower in Moscow, and about when that plan died. The sealed document does not appear on the docket of that case.
Når støvet vel har lagt seg, er nåværende POTUS bak lås og slå, eventuelt på den andre siden av den evige grensemuren. Jeg antar vel at sjansene for en genierklæring er om lag den samme som at Arne Treholt skulle komme til å bli genierklært i Norge. Eller litt mindre.Spørsmål til panelet:
Hva er sjansene for at Trump, etter at denne støyen har lagt seg, vil bli genierklært i ettertid for politikken og besluttningene han tok i løpet av sin tid som president?
-BB-
Takk,Når støvet vel har lagt seg, er nåværende POTUS bak lås og slå, eventuelt på den andre siden av den evige grensemuren. Jeg antar vel at sjansene for en genierklæring er om lag den samme som at Arne Treholt skulle komme til å bli genierklært i Norge. Eller litt mindre.Spørsmål til panelet:
-BB-
Disqutabel
Null. Se på Nixon. Han gjorde en del bra, tross alt, men huskes bare som den korrupte skurken som ble presset til å trekke seg. Du finner knapt noen som vil innrømme at de stemte på ham.Spørsmål til panelet:
-BB-
Hunter s Thompson's fantastiske nekrolog sier alt om Nixon: https://www.theatlantic.com/magazine/archive/1994/07/he-was-a-crook/308699/Null. Se på Nixon. Han gjorde en del bra, tross alt, men huskes bare som den korrupte skurken som ble presset til å trekke seg. Du finner knapt noen som vil innrømme at de stemte på ham.Spørsmål til panelet:
-BB-
