Det finnes mennesker som har håndledd større enn en gjennomsnitts hipster og da blir 42mm dameklokke å regne...Dessuten er alt over 42mm bare såååå 2015.
Det er vel en statussak, samt en funksjon av at klokker skal synes mer nå. Har sett temmelig grove håndledd med små ur og det er først i senere tid at ur har fått elefantiasis (kanskje man savner gamle dagers lommeur og vil ha dem på håndleddet.) I bransjen sier man at man må lage uret stort så det skal bli lett å se hva det er folk har på hånden, nå som folk er blitt meget bevisste det.Det finnes mennesker som har håndledd større enn en gjennomsnitts hipster og da blir 42mm dameklokke å regne...Dessuten er alt over 42mm bare såååå 2015.
In the late 1980s the mechanical watch was slowly coming back into fashion after the quartz watch market more or less killed it with cheaper prices and superior timing accuracy. Swiss watch brands were able to rebound (in a manner of speaking) by upgrading the status of the mechanical watch to being a luxury item versus a utility item. Case designs and quality improved, and by the 1990s timepieces were more than ever a status symbol and designer product versus mere tool to indicate the time. This meant that more emphasis was being placed on people seeing you wear a watch versus just the wearer being able to see it.
Further, as watch case and dial design became more complex, it was increasingly desirable for wearers to show off the artistic and decorative value of their watches – which meant that larger cases and dials were increasingly of interest. More so, as (mostly) mechanical watches became luxury items, watch features often increased in complexity. Thus, brands needed more dial real estate for the many complications that were becoming more and more popular compared to the traditional popularity of mostly time-only watches.
Therefore, one major reason for the overall increase in watch size is that timepieces became much more of a visual status symbol, and because watch designers began to offer increasingly complex designs that merited larger case sizes to show off.
Nettopp! Det er ikke alle av oss som klarer å ta seg selv rundt håndleddet... Og da kan en for liten klokke bli vel femininDet finnes mennesker som har håndledd større enn en gjennomsnitts hipster og da blir 42mm dameklokke å regne...Dessuten er alt over 42mm bare såååå 2015.
http://www.hifisentralen.no/forumet/off-topic-hja-rnet/16358-ny-klokke-181.html#post2759256Nettopp! Det er ikke alle av oss som klarer å ta seg selv rundt håndleddet... Og da kan en for liten klokke bli vel femininDet finnes mennesker som har håndledd større enn en gjennomsnitts hipster og da blir 42mm dameklokke å regne...Dessuten er alt over 42mm bare såååå 2015.
Proffen
Vet ikke helt om jeg "tog `an"....http://www.hifisentralen.no/forumet/off-topic-hja-rnet/16358-ny-klokke-181.html#post2759256Nettopp! Det er ikke alle av oss som klarer å ta seg selv rundt håndleddet... Og da kan en for liten klokke bli vel femininDet finnes mennesker som har håndledd større enn en gjennomsnitts hipster og da blir 42mm dameklokke å regne...Dessuten er alt over 42mm bare såååå 2015.
Proffen
Churchill hadde håndledd på 19cm og var meget fornøyd med sitt 36mm Datejust Jubilee. Det var også Eisenhower, som fikk samme ur og brukte det konstant. Klokkene ble blåst opp i størrelse på på tidlig 2000-tall, med Panerai i tet på 1990-tallet. Sylvester Stallone har en god del av skylden.
Her er jeg helt på linje med Trane, samtidig som jeg fullt ut anerkjenner Proffens argumenter.Det er jo helt innafor. Selv er jeg mer opptatt av det jeg finner litt utenom a4 når det gjelder klokker, enn jeg er av mer mainstream produkter. Det gjenspeiler seg også i samlingen. Er ikke mange 13 på dusinet-klokker der, nei.....Slike dingser synes jeg er bare påtatt elpekjekk "disainerklokke".
Ser ut som dansk design fra åttitallet og ser datert ut i det man tar de på armen.
Dessuten er alt over 42mm bare såååå 2015. 8)
Sorry, klarer bare ikke se noe positivt i skrytedingser som det der.
Proffen
...og det er til og med en ubetinget hyggelig tråd selv om smak og behag også på dette området spriker noget.Jøss, hvordan har jeg etter alle disse årene aldri sett klokketråden her på hfs. Hva i alle dager!
Det uret er laget for blinde og svaksynte. Veldig smart løsning med magneter (under skiven) der viserne normalt er, og stålkuler som følger magnetene rundt. Dermed tåler uret at stålkulene blir befølt og dyttet på, uten at verket påvirkes.Før eller siden er jeg nødt til å få denne i hus. Passe space, men uberkul, selv om den imho er litt liten i diameter, den skulle vært ca 45mm.
Vis vedlegget 501684
Proffen
COOL !Det uret er laget for blinde og svaksynte. Veldig smart løsning med magneter (under skiven) der viserne normalt er, og stålkuler som følger magnetene rundt. Dermed tåler uret at stålkulene blir befølt og dyttet på, uten at verket påvirkes.Før eller siden er jeg nødt til å få denne i hus. Passe space, men uberkul, selv om den imho er litt liten i diameter, den skulle vært ca 45mm.
Proffen
Akkurat spesiell nok til å vekke ha-begjæret.........Genialt armbåndsur for blinde og svaksynte.
Lekkert ur!
Proffen
https://www.tidssonen.no/forum/forums/marked-–-klokker.9/Fra en imbesil som har klart å miste sin kjære Oris:
Hvor er markedet for brukte mekaniske/automatiske ur?
Det er også en gruppe på facebook som heter Klokkeriet.Fra en imbesil som har klart å miste sin kjære Oris:
Har vært et par runder på massdrop med Oris nå i nyere tid, da får du en ny klokke til bruktpris eller bedre.Fra en imbesil som har klart å miste sin kjære Oris:
https://www.chrono24.no/Fra en imbesil som har klart å miste sin kjære Oris:
Har vært på tidssonen i en årrekke, mange seriøse der. Min erfaring er dog at mengden av Low balls og skambud er vel så høy der som på Finn.no!Tidssonen ser tilforlatelig ut. Takker!
Jeg har en Omega Constellation fra samme år som din, og som ligner veldig på din - fikk den av foreldrene mine da jeg ble myndig - og den var nettopp på service etter drøyt 10 år i skuffen. De byttet en haug med deler - bl.a. diverse tannhjul, opptrekkskrone, glass, pakninger og t.o.m. den delen med alle dato-tallene - og renset urverket etter alle kunstens regler. En nærmest total overhaling altså - men så var det hele nærmest nedslitt grunnet manglende service i altfor mange år.Jeg arvet en fin Omega Automatic klokke fra 1969.
Den ser veldig bra ut, men verdien er vel så som så.
Jeg tenker at det kanskje hadde vært greit men en sevice på denne, men hva er nødvendig og hva koster noe slikt.
Bor i Bergen, og håper noen i nærheten kan se på den.
En service vil ligge på alt fra 3-6K avhengig av ulike faktorer og og hvor mye du ønsker gjort (eks. polering, bytte av glass osv).Jeg tenker at det kanskje hadde vært greit men en sevice på denne, men hva er nødvendig og hva koster noe slikt.
